Software design
Program architecture
The software adopts a modular architecture design, mainly including four parts: core application framework, tool library, extension modules, and device interaction modules. Each module has clear responsibilities and low coupling, facilitating maintenance and expansion.
Business flow
Code details
Program Entry _main.py Initialization Flow
_main.py is the program entry file responsible for network preparation, application creation, and startup. The specific flow is as follows:
  • Network Waiting and Activation: Check network status through the wait_network_ready function. If not ready, configure APN and activate.
def wait_network_ready():
    wait_cnt = WAIT_NETWORK_READY_S / 5
    is_ready = False
    while wait_cnt:
       lte = dataCall.getInfo(1, 0)
       if lte[2][0] == 1:
           is_ready = True
           break
       utime.sleep(5)
       wait_cnt -= 1
    return is_ready
if __name__ == "__main__":
       if wait_network_ready():
           logger.debug('lte network normal')
           break
       logger.debug('wait lte network normal...')
       ret=dataCall.setPDPContext(1, 0, 'BICSAPN', '', '', 0)
       ret2=dataCall.activate(1)
       while not ret and ret2:
           if  ret and ret2:
               print("Net injection failure")
               break
  • Application Creation and Initialization: The create_app function initializes the application instance, loads configurations, and registers extension modules.
def create_app(name="meter_demo", version="1.0.0", config_path="/usr/config.json"):
   _app = Application(name, version)
   _app.config.init(config_path)
   qth_client.init_app(_app)
   meter_service.init_app(_app)
   return _app
  • Application Startup: After creating the application instance, call app.run() to start the application, execute system information printing and extension loading.
app = create_app()
app.run()
QTH Client Uploading Data to Cloud
qth_client.py implements QTH client functionality, responsible for communicating with the cloud. The data upload process is as follows:
  • Client Initialization: The init_app method of the QthClient class initializes QTH-related configurations and registers event callback functions.
def init_app(self, app):
   app.register("qth_client", self)
   qth_init.init()
   qth_config.setProductInfo(app.config["QTH_PRODUCT_KEY"], app.config["QTH_PRODUCT_SECRET"])
   qth_config.setServer(app.config["QTH_SERVER"])
   qth_config.setEventCb(
           "devEvent": self.eventCallback,
           "recvTrans": self.recvTransCallback,
           "recvTsl": self.recvTslCallback,
           "readTsl": self.readTslCallback,
           "readTslServer": self.recvTslServerCallback,
           "ota": {
               "otaPlan":self.otaPlanCallback,
               "fotaResult":self.fotaResultCallback
  • Data Sending Interface: Provides methods such as sendTsl, sendLbs, sendGnss for sending different types of data to the cloud. This solution only uses the sendTsl method.
def sendTsl(self, mode, value):
   return qth_bus.sendTsl(mode, value)
def sendLbs(self, lbs_data):
   return qth_bus.sendOutsideLocation(lbs_data)
def sendGnss(self, nmea_data):
   return qth_bus.sendOutsideLocation(nmea_data)
  • Data Upload Trigger: When receiving a command to read data, generate random simulation data in the readTslCallback method and upload it through the relevant mechanism.
def readTslCallback(self, ids, pkgId):
   logger.info("readTsl ids:{} pkgId:{}".format(ids, pkgId))
   value=dict()
# Generate various meter data...
# Send generated data through QTH client
Meter Data Update Logic
The meter data update logic is mainly implemented in the readTslCallback method of qth_client.py. When receiving a command to read data, it generates random meter data as follows:
  • Data Generation: Generate corresponding meter data according to different id, including total electricity, phase voltage, current, power, etc. Some data is generated based on random functions.
    value=dict()
    # Combine total active energy and other random simulation data generation
    com_total_active_energy = random_float(int(total_phase_a_energy + total_phase_b_energy + com_total_phase_c_energy), int(total_phase_a_energy + total_phase_b_energy + com_total_phase_c_energy), 2)
    com_forward_active_energy = random_float(4500, 5500, 2)
    com_reverse_active_energy = random_float(int(com_total_active_energy - com_forward_active_energy), int(com_total_active_energy - com_forward_active_energy), 2)
# Random simulation data generation for phase voltage, current, etc.
    voltage_a = 220.0
    current_a = random_float(9, 10, 2)
    # ... Other phase data generation
    # Map data according to id
    for id in ids:
       	if 1 == id:
           	value[1]=True
       	elif 2 == id:
           	value[2]=random_float(6000, 6600, 2)
    	# ... Mapping of other id corresponding data
  • Data Update Trigger: When the cloud or other modules trigger a command to read data, the readTslCallback method is called to generate the latest random data, realizing dynamic update of meter data.
