System login
2026-02-28
After installing the system, initialization information needs to be set for the first startup.
- Select a language.
- Select an input method.
- Select a Wi-Fi connection. If you prefer not to connect now, click "Skip" in the upper‑right corner.
- Set location services.
- Set the time zone.
- Set a username.
- Set a login password.
Note
Please make sure to remember your username and password for the next login.
- Initialization settings completed.
After logging in, the desktop will appear as shown in the figure below:
