Kernel compilation and update
This document describes the complete process of compiling the Linux kernel for Quectel Pi H1, packaging kernel images, and updating them to the device. Quectel Pi H1 uses a Yocto-based build system with a Qualcomm-customized Linux kernel (based on Linux 6.6).
Kernel recipes description
Qualcomm Linux kernel recipes are located in the /layers/meta-qcom-hwe/recipes-kernel/linux directory. This layer provides two kernel solutions:
| Recipe File | Kernel Type | Source | Description |
linux-qcom-custom_6.6.bb |
Custom BSP | git.codelinaro.org | Qualcomm-customized kernel (currently used) |
linux-qcom-base_6.6.bb |
Base BSP | git.kernel.org | Standard kernel |
Currently used: Custom kernel source solution
Directory structure
Kernel-related files are divided into two directories:
qcm6490-idp/
├── kernel-source/ # Kernel source directory
└── kernel-build-artifacts/ # Build artifacts directory
Kernel-source/ Directory
This directory stores the complete source code of the Linux kernel, including:
- Kernel core code (
arch/,drivers/,fs/,net/, etc.) - Device tree source files (
.dts/.dtsi, describing hardware configurations) - Kernel configuration files (
Kconfig) - Build scripts (
Makefile)
Source directory details
| Directory/File | Description | Directory/File | Description |
| arch | Architecture-related code (ARM64, x86, etc.) | scripts | Compilation and configuration scripts |
| block | Block device subsystem | security | Security framework (SELinux, AppArmor, etc.) |
| certs | Kernel certificates and signatures | sound | Audio subsystem (ALSA) |
| crypto | Encryption API and algorithms | tools | Kernel-related tools |
| Documentation | Kernel documentation | usr | initramfs generation related |
| drivers | Device drivers | virt | Virtualization support (KVM) |
| fs | File system implementation | rust | Rust language support |
| include | Kernel header files | Makefile | Main configuration file |
| init | Kernel initialization code | Kbuild | Kernel build system configuration |
| ipc | Inter-process communication mechanisms | Kconfig | Kernel configuration interface definition |
| kernel | Kernel core functionalities (scheduler, process management, etc.) | MAINTAINERS | Maintainer list |
| lib | Common library functions | CREDITS | Contributor list |
| mm | Memory management subsystem | COPYING | Copyright notice (GPL) |
| net | Network protocol stack | ||
| samples | Kernel programming example code |
Kernel-build-artifacts/ Directory
This directory stores kernel build artifacts after compilation, including:
- Kernel image files:
Image(uncompressed) orImage.gz(compressed version) - Device tree binary files:
.dtbfiles (compiled from.dts) - Kernel modules:
.kofiles (loadable driver modules) - Configuration files:
.config,build.log, etc.
Compile kernel
1. Configure build environment
Enter the code working directory and execute the following command to configure the build environment:
2. Execute compilation
Use Yocto's bitbake command to compile the kernel:
bitbake linux-qcom-custom
3. Build artifact paths
After compilation is complete, the kernel image is generated at the following location:
Temporary working directory:
build-qcom-wayland/tmp-glibc/work/qcm6490_idp-qcom-linux/linux-qcom-custom/6.6/deploy-linux-qcom-custom
Final deployment directory (automatically copied by Yocto):
build-qcom-wayland/tmp-glibc/deploy/images/qcm6490-idp/
Note: Yocto will automatically copy the kernel image from the working directory to the deployment directory. During the subsequent packaging process, the kernel image is obtained from the deployment directory.
Build time reference
- First build: Approximately 30–60 minutes (depending on hardware configurations)
- Incremental build: Approximately 5–15 minutes
Package kernel and device tree images
1. Install ukify tool
First, install the Python dependencies required for packaging:
sudo pip install pefile
2. Execute packaging command
Run the following command to package the kernel image and device tree:
do_kernel_images
3. ukify warning description
During the packaging process, the following warning messages will appear, which can be ignored:
Kernel version not specified, starting autodetection .
Real-Mode Kernel Header magic not found
+ readelf --notes {TOPDIR}/quectel_build/alpha/tools/pack/image_temp/Image
readelf: Error: Not an ELF file - it has the wrong magic bytes at the start
Found uname version: 6.6.52-qli-1.3-ver.1.1
Wrote unsigned ${TOPDIR}/quectel_build/alpha/tools/pack/image_temp/uki.efi
Note: These warnings are caused by differences between ARM64 kernel format and EFI tool expected format, and do not affect the correctness of the final image.
4. Get packaged image
After packaging is complete, obtain the generated image file from the following path:
${TOPDIR}/quectel_build/alpha/output/pack/efi.bin
Update image to device
Method 1: Enter Fastboot via debug UART
1. Enter Fastboot mode
Option A - Via serial port command:
Connect the debug UART and execute in the system:
reboot bootloader
Option B - Via ADB command:
Ensure the device is connected via USB and ADB debugging is enabled, then execute:
adb shell
reboot bootloader
2. Verify Fastboot mode
After the device enters Fastboot mode, run on the host:
fastboot devices
Now you can see the device list.
3. Flash kernel image
Use the fastboot command to flash the new kernel image:
fastboot flash efi efi.bin
4. Reboot device
After flashing is complete, reboot the device:
fastboot reboot
Method 2: Automation script (optional)
If you need to frequently update the kernel, you can create an automation script:
#!/bin/bash
# update_kernel.sh
# Check if efi.bin exists
if [ ! -f "quectel_build/alpha/output/pack/efi.bin" ]; then
echo "Error: efi.bin does not exist, please compile and package the kernel first."
exit 1
fi
# Enter Fastboot
adb reboot bootloader
sleep 5
# Wait for Fastboot to be ready
fastboot devices
# Flash image
fastboot flash efi quectel_build/alpha/output/pack/efi.bin
# Reboot
fastboot reboot
echo "Kernel update complete!"
Usage:
chmod +x update_kernel.sh
./update_kernel.sh
Notes
- Backup important data: Before updating the kernel, ensure important data is backed up.
- Sufficient power: Ensure the device has sufficient power or is connected to power during flashing.
- Stable USB connection: Use a good quality USB cable to avoid flashing interruption.
- Version matching: Ensure the kernel version is compatible with other system components.
FAQs
Q1: bitbake compilation failed?
Possible causes:
- Insufficient disk space
- Network connection problems
- Missing dependency packages
Solution:
# Clean build cache
bitbake -c cleanall linux-qcom-custom
# Recompile
Q2: Device cannot be seen after Fastboot mode is verified?
Solution:
- Check if USB drivers are correctly installed
- Try changing USB port or cable
- Confirm the device has correctly entered Fastboot mode (screen displays Fastboot text)
Q3: Cannot boot after flashing?
Solution:
- Use factory image to restore the system
- Check if there were errors during compilation
- Confirm device tree configuration is correct
