Smart vision car
The smart vision car is designed for educational research, robotics innovation, and embedded smart application validation scenarios. It is equipped with Quectel Pi H1 smart single-board computer, ROS 2 software stack, and multi-sensor hardware, and can be quickly started through mobile App, Docker/ROS environment, and WonderPi kit. This document outlines development resources, assembly steps, environment deployment, and gameplay examples to help you complete software and hardware debugging and testing in the shortest time and put it into teaching or project demonstrations.
Application product features
  • Integrated smart vision solution: Integrates high-definition camera with gimbal, ultrasonic sensor, line-following sensor, and omnidirectional chassis.
  • Dual-stack development (software and hardware): Provides Docker images, ROS 2 workspace, and mobile control for secondary development.
  • Multiple gameplay examples: Built-in examples including remote control, target tracking, color line following, QR code recognition, intelligent obstacle avoidance.
  • Quick replication and deployment: Corresponding environment scripts and system services are provided.
Support list
Category Supported content
Hardware platform Quectel Pi H1 smart single-board computer + expansion board, gimbal camera, ultrasonic sensor, line-following sensor, TT motors, 18650 battery box
System/software Debian 13, Docker, ROS 2 Humble, App (Android/iOS)
Interface capabilities I2C9, UART12, GPIO, PWM servo interface, four-channel line-following sensor interface
Control methods Mobile App direct connection/LAN, ADB/SSH, Docker container
Development resources summary
Development accessories list
  • Buy smart vision car kit.
  • The kit includes structural components such as profiles/electronics/screws, 18650 battery box, main control board and expansion board, gimbal camera, tool accessories, etc. See the physical reference below for details.
Physical reference of accessories
The following images provide physical references for equipment, electronic components, screws, and tools to facilitate quick verification and material management after arrival.
Profile accessories
Screw accessories
Electronic accessories
Tools
Pre-use assembly instructions
Assembly steps
  • Use 4 M2*5 round head self-tapping screws to install the LED ultrasonic sensor to the ultrasonic bracket.
  • Use 2 M2*4 round head machine screws to install the PWM servo on the base bracket; use 2 black M3*6 round head machine screws to install the assembled ultrasonic bracket on the base bracket (connect the 4pin wire before assembly).
  • Use 8 M3*25 machine screws and 8 M3 nuts to fix the four TT motors to the chassis.
  • Use 2 M4*8 round head machine screws and 2 M4*28 brass standoffs to fix them on the chassis. Then use 2 M4*8 round head machine screws to fix the four-channel line-following sensor on the chassis. After installing the four-channel line-following sensor, insert one end of the 4pin wire into the sensor interface.
  • Use 4 black M3*6 round head machine screws to install the assembled base bracket on the chassis.
  • Use 3 M2.5*5 unthreaded Nylon spacers and 3 M2.5*10 threaded Nylon standoffs to fix the main board. Align the female headers of the expansion board with the male headers of the main board (pin-to-pin allignment) and insert them into the main board. Then use 2 M2.5*6 round head machine screws to fix the expansion board and main board together.
  • Use 4 M2.5*6 round head machine screws to fix the assembled main board on the chassis, and connect the four-channel line-following sensor and LED ultrasonic sensor to the corresponding interfaces on the expansion board.
  • Use 4 M3*4 flat head machine screws to fix the battery box under the chassis.
  • Install the coupling on the axle of the TT motor, and use 4 pan head semi-machine thread self-tapping M2.3*25 screws to fix the Mecanum wheel with the axle of the TT motor.
  • Use 2 M2*4 round head self-tapping screws to fix the plastic shaft on the gimbal U-shaped bracket, then use 1 M2*4 round head self-tapping screw to install the assembled gimbal U-shaped bracket on the car.
  • Use 2 M2*12 round head machine screws and 2 M2 nuts to fix the PWM servo on the gimbal camera bracket.
  • Use 4 M2*4 round head machine screws and 4 M2*8 knurled brass standoffs to fix them on the gimbal camera bracket. Then use 2 M2*4 round head machine screws to fix the camera on the gimbal camera bracket.
  • Use 1 M2*6 round head self-tapping screw to fix the assembled gimbal camera bracket on the car.
  • Connect the 4 TT motor interfaces and 2 gimbal servo interfaces (orange to S (signal wire), red to +, brown to -) with the expansion board.
  • After installation, the car body is as follows.
Pre-use environment deployment
Download environment
Before use, you need to download the relevant environment. The download link is as follows:
Deployment environment
After downloading the deployment environment, push the deployment environment to the device via adb push, then decompress it.
# Push to device
adb push ./qpi_smartcar.zip /mnt
adb shell
# Decompress the package:
unzip /mnt/qpi_smartcar.zip -d /mnt/
# Add executable permissions to all files in the run/ directory and deploy_container.sh:
chmod +x /mnt/qpi_smartcar/service_config/run/*
chmod +x /mnt/qpi_smartcar/deploy_container.sh
After decompression, you can get the following directory structure:
qpi_smartcar/
├── docker_images/
│   └── docker_qpi_smart_car.tar    # Docker image file
├── ros2_ws/
│   ├── src/                           # ROS2 source code
│   └── software/                      # software tools
├── service_config/
│   ├── rules.d/                       # udev rule files
│   ├── service/                       # systemd service files
│   └── run/                           # Boot fast start scripts
└── deploy_container.sh                # Complete deployment script
Ensure communication
To ensure the communication between Quectel Pi smart single-board computer and expansion board, you need to enable i2c9 and uart12 on the 40pin. The enabling method is as follows:
  • On the Quectel Pi smart single-board computer, modify the qpi-config.ini configuration file. First, run the following command to open the file: vi /etc/qpi-config/qpi-config.ini, then modify the content as follows:
    i2c9=enable
    spi10=disable
    uart12_2w=enable
    i2c13=disable
    spi14=disable
    heartbeat_color=green
    led_red_brightness=0
    led_blue_brightness=0
    led_green_brightness=0
    heartbeat_switch=on
  • Enter qpi-config 40pin set, then restart the Quectel Pi smart single-board computer to take effect.
Complete deployment process
After the above restart, you need to plug in the network cable or connect to Wi-Fi to ensure you have access to the internet, then execute the deployment script deploy_container.sh.
# Run complete deployment
After the deployment script is executed, the following prompt will appear if successful:
[SUCCESS] Deployment completed successfully!
ROS2 application has been automatically started!
Pre-use device preparation
Battery charging
Since the battery cannot be fully charged during transportation, it is recommended to fully charge the battery before the first startup. The specific charging method is as follows:
  1. Take out the battery charger, install two 18650 batteries (optional) into the battery charger according to the positive and negative poles (positive to positive, negative to negative). Note! Do not reverse the positive and negative poles of the battery! Then connect the battery charger (optional) and charging head (5V 3A, need to be prepared by yourself) through a data cable, and finally connect to the power supply.
  1. Wait for the charging to complete (the indicator light defaults to be green when the adapter is powered on; after a depleted battery is correctly installed, the indicator light should turn red (indicating charging in progress, which takes approximately 5 hours); when the indicator light changes from red back to green, it means charging is complete). After charging is complete, please unplug the charger as soon as possible and do not keep it charging continuously.
  2. After charging is complete, please ensure that the battery box switch is set to "OFF" before installing the battery (see Startup preparation section for OFF position).
Mobile App installation
Android: Scan the QR code below for installation.
iOS: You can go to the App Store and search "WonderPi" to download and install it.
Startup preparation
  1. Install two charged 18650 batteries in the battery box at the bottom of the car matching the positive and negative poles, then turn the bottom switch to "ON".
  1. Then push the expansion board switch from "OFF" to "ON". At this time, LED1 and LED2 of the expansion board stay on. After a moment, LED1 starts blinking once per second, the gimbal resets to its home position, and the buzzer beeps once to confirm successful startup (Please wait about 30 seconds for the beep).
Note:
  • LED2 is the power indicator, which lights up when powered on and is always on during device operation. If the light dims, it means the power is dead and needs to be charged;
  • LED1 is the communication indicator. The device's default network connection mode is direct connection mode. After the device starts successfully, LED1 blinks once per second; if it is set to LAN mode, LED1 will be always on;
  • During device operation, if LED1 and LED2 lights dim and remain always on, it means the power is dead and needs to be charged.
Gameplay trial
Pre-use connection
  1. After the device starts successfully, it will enter AP direct connection mode and generate a hotspot starting with "HW". Open the mobile App "WonderPi" on your phone, and click "Beginner Kit" and "TurboPi" in sequence.
  1. Click the "+" button in the lower right corner of the interface and select "Direct Connection Mode".
  1. Click the "Connect to Device Hotspot" button to the settings interface and connect to the hotspot starting with "HW". When connecting, you need to enter the password "hiwonder".
  1. After successful connection, return to the mobile App and wait for a moment. When the icon shown in the figure below is found, the connection is successful (If it is not displayed below the device list, you can click the refresh button in the upper right corner to refresh the device).
Note: If a popup prompt "Network unavailable, continue to connect?" appears, click the "Keep Connection" button.
  1. Click the TurboPi icon in the figure above to enter the gameplay mode selection interface, as shown below:
Body remote control
Introduction: This mode can control the car movement and ultrasonic RGB lights in real time; the interface is divided into four parts, the descriptions and function icons of each part are as follows:
① Status bar: Controls exiting gameplay, taking screenshots of the return video, and hiding the status bar;
② Control bar: Controls car movement;
③ Return video: Shows the return video of the camera and displays the device voltage value;
④ Ultrasonic RGB light adjustment function: Controls the on/off status of the ultrasonic module's RGB light and its display of different colors.
The operations are described as follows:
Interface Distribution Icon Corresponding Function
Control bar
Drag the middle button to control the TurboPi car body to move in all directions.
Click or long press this icon to control the TurboPi car body to rotate counterclockwise in place.
Click or long press this icon to control the TurboPi car body to rotate clockwise in place.
To return to the gameplay mode selection interface, click the return arrow in the upper left corner.
Target tracking
Introduction: Click "Target Tracking" to enter the gameplay interface. After this gameplay mode is started, it can realize the function of the car moving with the movement of the target color.
The operation steps are as follows:
  1. In the above figure, click the button at ① will change from "Color Pick" to "Confirm Color Pick". In the video captured by the camera on the right, move the red dot to select the target color, then click "Confirm Color Pick" to confirm the color;
  2. Click the "Gimbal Tracking" button at ② to start the tracking gameplay mode. At this time, the device's camera will follow the selected color target movement, and the car body will not move;
  3. To realize the car body following gameplay mode, you need to select both the "Gimbal Tracking" at ② and the "Body Follow" at ③ buttons. At this time, the device's car body and gimbal will follow the selected color target movement.
Note:
  • Please use it in a well-lit indoor environment, but try to avoid direct strong light.
  • During recognition, please avoid having objects in the camera view with the same color as or similar color to the target color, to prevent interference with the recognition process.
Color line following
Introduction: Click "Color Line Following" to enter the gameplay interface. After this gameplay mode is started, the car can move forward along black or red lines.
  2. Click the "Start" button at ② to move forward along the line of the target color.
Note:
QR code recognition
Introduction: Click "QR Code" recognition to enter the gameplay interface. After this gameplay mode is started, the car's camera can recognize different QR codes and execute corresponding actions.
① The left side of the interface is the QR code switch and selection area;
② The right side of the interface is the QR code screen.
Click the "Start Recognition" button and select different QR codes. Place the QR code in front of the device's camera for recognition. The device will execute different actions after recognizing different QR codes.
Button icon Function description
QR code for the car to execute forward action
QR code for the car to execute backward action
QR code for the car to execute left movement action
QR code for the car to execute right movement action
Display selected QR code information
Note:
  • The distance for recognizing QR codes should not be too close or too far. Generally, a distance of 35 cm between a QR code image and the camera yields is the best.
Smart obstacle avoidance
Click "Smart Obstacle Avoidance" to enter the gameplay interface. After this gameplay mode is started, the car can identify whether there are obstacles ahead through ultrasonic waves and avoid them.
① The left side of the interface is the obstacle avoidance gameplay mode switch and obstacle threshold setting area;
② The middle of the interface is the camera return video area;
③ The right side of the interface is the RGB light and motor speed setting area.
Click the "Start Obstacle Avoidance" button, and the device will keep moving forward. When it detects an obstacle, it will turn left until there is no obstacle and continue moving forward.
Turn on/off gameplay.
Adjust obstacle threshold, unit: cm.
Turn on/off ultrasonic RGB light.
Adjust ultrasonic RGB light color.
Adjust motor speed, the higher the value, the faster the motor speed.
Note: Do not detect objects at close range for a long time.
