Add applications and third-party libraries
This document guides users to add custom applications and third-party libraries to the Yocto build system (using helloworld as an example). Through the steps in this document, you can:
- Integrate custom code into Yocto projects
- Generate IPK installation packages
- Compile and use third-party library files
- Integrate components into system images
Prerequisites
Environment requirements
- Necessary development toolkits installed
- Yocto project code cloned
- Familiar with basic C programming
- Understand Makefile and BitBake basics
Project directory structure
Create a custom meta layer. Recommended directory structure:
meta-custom/
├── conf/
│ └── layer.conf # Layer configuration file
├── recipes-apps/ # Application recipe directory
│ └── helloworld/
│ ├── files/
│ │ ├── helloworld.c # Application source code
│ │ ├── Makefile # Build script
│ │ └── helloworld.service # systemd service file
│ └── helloworld_1.0.bb # BitBake recipe
└── recipes-libs/ # Library recipe directory
└── lib-helloworld/
├── files/
│ ├── lib_helloworld.c # Library source code
│ ├── lib_helloworld.h # Library header file
│ └── Makefile # Build script
└── lib-helloworld_1.0.bb # BitBake recipe
Add custom applications
1. Create layer directory structure
Create directories
Configure custom layer
Add the following to the layers/meta-custom/conf/layer.conf file:
BBPATH .= ":${LAYERDIR}"
Register layer to build system
Edit layers/meta-qcom-distro/conf/bblayers.conf by adding the custom layer path:
BBLAYERS = " \
Add to image recipe
Edit layers/meta-quectel/recipes-products/images/qcom-multimedia-image.bbappend by adding:
# Add the application
IMAGE_INSTALL:append = " helloworld"
# Add library files (if needed)
IMAGE_INSTALL:append = " \
lib-helloworld \
lib-helloworld-dev \
lib-helloworld-staticdev \
2. Create application source code
Write main program
Create helloworld.c in the meta-custom/recipes-apps/helloworld/files/ directory:
// helloworld.c
#include <stdio.h>
int main() {
printf("Hello, world!\n");
Write Makefile
Create Makefile in the meta-custom/recipes-apps/helloworld/files/ directory:
# Use compilation flags provided by Yocto
all: helloworld
helloworld: helloworld.c
clean:
rm -f helloworld
.PHONY: all clean
Create Systemd service file
Create helloworld.service in the meta-custom/recipes-apps/helloworld/files/ directory:
[Unit]
[Service]
Type=simple
ExecStart=/usr/bin/helloworld
[Install]
WantedBy=multi-user.target
3. Write BitBake recipe
Create helloworld_1.0.bb in the meta-custom/recipes-apps/helloworld/ directory:
LICENSE = "MIT"
# Source code file list
file://Makefile \
file://helloworld.service"
# Set working directory
S = "${WORKDIR}"
# Inherit the systemd class
inherit systemd
# Define systemd service file name
# Configuration phase (skip)
do_configure() {
bbnote "skip do_configure"
# Compilation phase
do_compile() {
# Clean first
# Compile
# Installation phase
do_install() {
# Create the installation directory of the executable file
install -d ${D}${bindir}
# Install the executable file
# Create the systemd service directory
# Install the service file
4. Build and install application
Configure build environment
Enter the code working directory and execute:
Method 1: Compile and install IPK package separately
Step 1: Compile the application
bitbake helloworld
Step 2: Find the generated IPK package
Example output:
Step 3: Push to device
adb push helloworld_1.0-r0_armv8-2a.ipk /mnt
Step 4: Install the IPK package
Execute the following command on the device:
# Mount the file system as read-write mode
mount -o remount,rw /usr
# Install the IPK package
opkg install /mnt/helloworld_1.0-r0_armv8-2a.ipk
Step 5: Verify the installation
/usr/bin/helloworld
Expected output:
Hello, world!
Method 2: Compile the entire system image
Step 1: Configure the build parameters
# Users can customize the input parameters, and select from the prompted valid options
buildconfig QSM565DWF QSM565DWFPIARL1A01_BL01BP01K0M01_QDP_LP6.6.0XX.01.00X_V0X STD
Step 2: Compile the entire system
buildall
Step 3: Package the image
buildpackage
Step 4: Flash the image
The generated image is at quectel_build/QSM565DWFPIARL1A01_BL01BP01K0M01_QDP_LP6.6.0XX.01.00X_V0X.
Refer to the following documents for flashing:
After the flashing is complete, execute the following command on the device:
/usr/bin/helloworld
Expected output:
Hello, world!
Add third-party libraries
1. Create library files
Create directory
Create library header file
Create lib_helloworld.h in the meta-custom/recipes-libs/lib-helloworld/files/ directory:
// lib_helloworld.h
#ifndef LIB_HELLO_H
#define LIB_HELLO_H
void hello_print(const char* name);
#endif
Create library source code
Create lib_helloworld.c in the meta-custom/recipes-libs/lib-helloworld/files/ directory:
// lib_helloworld.c
#include <stdio.h>
#include "lib_helloworld.h"
Write Makefile
Create Makefile in the meta-custom/recipes-libs/lib-helloworld/files/ directory:
LIB_VERSION = 1.0
all:
clean:
rm -f libhello.so* lib_helloworld.o libhello.a
2. Write BitBake recipe
Create lib-helloworld_1.0.bb in the meta-custom/recipes-libs/lib-helloworld/ directory:
SECTION = "libs"
LICENSE = "MIT"
file://lib_helloworld.h \
file://Makefile"
S = "${WORKDIR}"
do_install() {
# Create target directories
install -d ${D}${libdir}
install -d ${D}${includedir}
# Install shared library and symbolic links
# Install the static library
# Install the header file
install -m 0644 ${S}/lib_helloworld.h ${D}${includedir}/
# Allocate the package files
FILES:${PN} = " \
${libdir}/libhello.so.1 \
${libdir}/libhello.so.${PV} \
FILES:${PN}-dev = " \
${libdir}/libhello.so \
${includedir}/lib_helloworld.h \
FILES:${PN}-staticdev = " \
${libdir}/libhello.a \
3. Build and use third-party libraries
Method 1: Compile and install separately
Step 1: Compile the library
bitbake lib-helloworld
Step 2: Find the generated library files
find ./* -name "libhello*"
Step 4: Fix permissions and symbolic links
Execute on the device:
# Set execute permissions
chmod 755 /usr/lib/libhello.so*
chmod 644 /usr/lib/libhello.a
# Rebuild symbolic links
cd /usr/lib
Step 5: Write the test program
Create the static library test program static_test_helloworld.c:
#include <stdio.h>
int main() {
printf("static lib test\n");
hello_print("world");
Create the dynamic library test program dynamic_test_helloworld.c:
#include <stdio.h>
int main() {
printf("dynamic lib test\n");
Step 6: Compile and run the test program
Static library test:
./static_hello
Expected output:
static lib test
[LIB] Hello, world!
Dynamic library test:
./dynamic_hello
Expected output:
dynamic lib test
[LIB] Hello, world!
Compile and flash
Refer to the steps in the "Method 2: Compile the entire system image" section of the "Add custom applications" chapter for compilation and flashing.
Verify library files
After the flashing is complete, check library files on the device:
ls -l /usr/lib/libhello*
Expected output:
-rw-r--r--. 2 root root 5002 Jan 1 1970 /usr/lib/libhello.a
lrwxrwxrwx. 1 root root 15 Jul 25 06:26 /usr/lib/libhello.so -> libhello.so.1.0
lrwxrwxrwx. 1 root root 15 Jul 25 06:26 /usr/lib/libhello.so.1 -> libhello.so.1.0
-rwxr-xr-x. 2 root root 5968 Jan 1 1970 /usr/lib/libhello.so.1.0
Run test program
./static_hello
Expected output:
static lib test
[LIB] Hello, world!
./dynamic_hello
Expected output:
dynamic lib test
[LIB] Hello, world!
Notes
- Layer priority: Ensure that the custom layer configuration is correct to avoid conflicts with other layers
- License declaration: Must correctly set LICENSE and LIC_FILES_CHKSUM
- File permissions: Pay attention to the permission settings of the executable and library files
- Symbolic links: Dynamic library symbolic links must be correctly set
- Dependencies: If the library depends on other packages, declare DEPENDS in the recipe
- Version management: It is recommended to use version numbers to manage library files
FAQs
Q1: BitBake compilation failed?
Check items:
- Is the recipe syntax correct
- Are source file paths correct
- Does the LICENSE file exist
Q2: IPK installation failed?
Solution:
- Ensure that the filesystem is mounted as read-write mode
- Check if disk space is sufficient
- View opkg error logs
Q3: Dynamic library not found?
Solution:
- Check LD_LIBRARY_PATH environment variable
- Confirm symbolic links are correct
- Run
ldconfigto update the library cache
Related Documents
- Development environment setup
- Image build
- Image flashing
- Cross-Compilation toolchain
- Kernel compilation and update
Summary
Through the guidance in this document, in the Yocto environment, you can:
- Create custom applications and libraries
- Generate IPK installation packages for separate deployment
- Verify and test custom components
After mastering these skills, you can expand and customize system functionalities according to actual needs.
