Remote debugging
Remote debugging refers to the technology of connecting to a remote device (Quectel Pi H1) from a local development machine through a network for code debugging, problem troubleshooting, and performance analysis. Compared to debugging directly on the device, remote debugging has the following advantages:
- Improved development efficiency: No need to frequently plug and unplug devices, can debug remote code directly in local IDE
- Convenient file transfer: Can quickly upload/download code and files
- Flexible debugging methods: Supports command-line debugging, GUI debugging, and other methods
- Save physical resources: No need to connect monitors, keyboards, and other peripherals
Prerequisites
Before performing remote debugging, you need to ensure:
Network connection: Quectel Pi H1 is connected to the network (wired or through Wi-Fi)
- Wired network: Plug in the network cable, and the device will automatically obtain IP (DHCP protocol)
- Wi-Fi: Enter the Wi-Fi password to connect, the device will automatically obtain IP (DHCP protocol)
Get device IP address: Enter the following command in the debug UART terminal to view the IP address
ip address # or ifconfigEnsure the local computer and device are on the same LAN
Remote access methods
According to different debugging needs, you can choose the following remote access methods:
1. SSH remote terminal
Application scenario: Command-line debugging, code compilation, system management
SSH (Secure Shell) is the most commonly used remote terminal access method, providing encrypted command-line connections.
Detailed documentation: Please refer to SSH Remote Terminal
Quick start:
# Linux system (ssh-server is built-in by default)
ssh pi@192.168.2.xxx
# If you need to install ssh-server
sudo apt install openssh-server
sudo systemctl enable ssh
sudo systemctl start ssh
Debugging advantages:
- Lightweight, low resource consumption
- Supports SSH tunneling, can perform port forwarding
- Can be integrated with IDEs like VS Code, PyCharm for remote debugging
2. VNC remote desktop
Application scenario: GUI debugging, visual tool debugging
VNC (Virtual Network Computing) provides remote graphical desktop access, allowing you to see the complete desktop environment of the remote device locally.
Detailed documentation: Please refer to VNC Remote Desktop
Port description:
- Default port
5900or5901
- Complete graphical interface support
- Suitable for debugging graphical applications
- Can run GUI debugging tools
3. TeamViewer remote desktop
Application scenario: Cross-platform remote control, temporary remote assistance
TeamViewer is a commercial remote desktop software that supports multiple platforms including Windows, Mac, Linux, etc.
Detailed documentation: Please refer to TeamViewer Remote Desktop
- Good cross-platform support
- Stable connection, suitable for long-term debugging
- Supports file transfer and remote printing
4. SCP file transfer
Application scenario: Code file upload/download, log file retrieval
SCP (Secure Copy Protocol) is based on SSH protocol, used for secure file transfer between local and remote devices.
Detailed documentation: Please refer to SCP File Copy
Common commands:
# Upload file to device
scp ~/my_program pi@192.168.2.xxx:/home/pi/
# Download device file to local
scp pi@192.168.2.xxx:/var/log/app.log ./
# Recursively copy directory
scp -r ~/my_project pi@192.168.2.xxx:/home/pi/
5. Samba file sharing
Application scenario: Large project file transfer, frequent file exchange
Samba provides Windows-style network file sharing, allowing direct access to device files in Windows Explorer.
Detailed documentation: Please refer to Samba File Sharing
Access method:
- Windows: Enter
\\192.168.2.xxxin Explorer - Enter username and password to access shared folders
6. Apache web server
Application scenario: Web application debugging, remote access to web interface
Apache Web server can be used to deploy web applications and access remotely through a browser.
Detailed documentation: Please refer to Apache Web Server
Common issue troubleshooting
1. Cannot SSH connect
- Check network connection:
ping 192.168.2.xxx - Check SSH service status:
sudo systemctl status ssh - Check firewall settings:
sudo ufw status
2. VNC connection failed
- Check if VNC service is running:
ps aux | grep vnc - Check if port is listening:
netstat -tln | grep 59 - Confirm firewall allows VNC port
3. Missing debug symbols
- Ensure
-goption is added during compilation - Check debug information:
file my_programorreadelf -w my_program
4. Permission issues
- Use
sudoto elevate privileges - Check file permissions:
ls -l - Modify file permissions:
chmod +x my_program
Summary
Remote debugging is an important skill in embedded development. Choose the appropriate tool according to different debugging needs:
- Command-line access: SSH remote terminal
- Graphical interface access: VNC or TeamViewer
- File transfer: SCP or Samba
- Web service: Apache web server
Reasonably combining these tools can greatly improve development efficiency and debugging experience.
