wx图形界面开发
2026-05-19
wxWidgets是一个开源的跨平台图形界面库,提供C++、Python、Ruby、Lua和Perl接口,下面是基于Python开发图形界面APP的步骤演示。
环境准备
sudo apt-get update -y
sudo apt install -y python3-wxgtk4.0
代码编写
import wx
import sys
import os
class ImageViewerFrame(wx.Frame):
def __init__(self, parent, title, image_path):
super().__init__(parent, title=title, size=(800, 600))
self.panel = wx.Panel(self)
self.image_ctrl = wx.StaticBitmap(self.panel, wx.ID_ANY)
self.sizer = wx.BoxSizer(wx.VERTICAL)
self.sizer.Add(self.image_ctrl, 1, wx.EXPAND | wx.ALL, 10)
self.panel.SetSizer(self.sizer)
self.load_image(image_path)
def load_image(self, file_path):
image = wx.Image(file_path)
self.image_ctrl.SetBitmap(wx.Bitmap(image))
self.SetTitle(f"IMAGE VIEWER - {os.path.basename(file_path)}")
self.panel.Layout()
except Exception as e:
wx.MessageBox(f"IMAGE LOADING FAIL:{str(e)}", "ERROR", wx.OK | wx.ICON_ERROR)
self.Close()
class ImageViewerApp(wx.App):
def OnInit(self):
if len(sys.argv) < 2:
wx.MessageBox("USAGE:python3 test.py <image file path>", "ARG ERROR", wx.OK | wx.ICON_WARNING)
return False
image_path = sys.argv[1]
frame = ImageViewerFrame(None, title="IMAGE VIEWER", image_path=image_path)
frame.Centre()
frame.Show(True)
return True
if __name__ == "__main__":
app = ImageViewerApp(False)
app.MainLoop()
运行
python3.13 test.py <image file path>
运行结果
