Specifications
Note: Unless otherwise specified, an asterisk ( * ) after a function, feature, interface, pin name, command, argument, and so on indicates that it is under development and currently not supported; and the asterisk ( * ) after a model indicates that the model sample is currently unavailable.
Specifications parameters
Quectel Pi M1 Description
Package PCBA
Size (mm) (85 ± 0.2) × (56 ± 0.2) × (21.66 ± 0.2)
Weight (g) –
Key parameters
Category Description
Application processor Octa-core 64-bit ARM Kryo™ 260 processor:
4 × A73 @ 2.0 GHz, 1 MB L2 cache
4 × A53 @ 1.8 GHz, 512 KB L2 cache
GPU 64-bit Adreno™ 610 @ 1050 MHz
Storage 64 GB eMMC + 4 GB LPDDR4X
Operating system Linux/Android/Ubuntu*
USB interface 1 × USB 3.0 Type-C interface with a data transfer rate up to 5 Gbps, used for firmware flashing (requires shorting BOOT) and host mode communication
2 × Standard USB 3.0 Type-A interfaces, host mode only, data transfer rate up to 5 Gbps
2 × Standard USB 2.0 Type-A interfaces, host mode only, data transfer rate up to 480 Mbps
1 × USB Type-C interface, main power supply interface
SIM interface 2 × (U)SIM interfaces, 1.8/2.95 V SIM cards, dual SIM dual standby (Nano SIM and eSIM)
Display interface 1 × Micro HDMI interface, Micro HDMI 2.0 (frame rate*), encoding: 1080P (H.264/H.265) @ 60 fps*), decoding: 1080P (H.264/H.265/VP9) @ 60 fps*)
1 × FPC connector, based on MIPI standard FHD+ (1080 × 2520) @ 60 fps*
Audio interface 1 × SH1.0-4P audio interface
1 × Micro HDMI interface, audio output
1 × MEMS microphone
Camera interface 2 × FPC connectors, 4-lane MIPI CSI, speed up to 2.5 Gbps/lane
Ethernet interface 1 × Standard RJ45 interface, 10/100/1000 Mbps Ethernet. Supports POE function
SD interface 1 × SD 3.0, 4-bit SDIO
UART interface 2.54 mm header (1 × 3 pins), debug use only
Expansion interfaces 4 × I2C interfaces (multiplexed with other interfaces)
3 × SPI interfaces (multiplexed with other interfaces, master mode only)
4 × UART interfaces (multiplexed with other interfaces)
28 × GPIO interfaces (multiplexed with other interfaces)
Button interfaces 1 × PWRKEY, internal pull-up
LED indicators Blue and Green
Antenna interfaces 1 x MAIN, main antenna
1 x DRX, diversity reception antenna
1 x GNSS, GNSS antenna
1 × Wi-Fi/BT, Wi-Fi and Bluetooth antenna
LTE Compliant with 3GPP Rel-10 FDD and TDD
GNSS GPS, GLONASS, BDS, Galileo, QZSS and SBAS positioning systems
WLAN Operation modes: AP and STA
Operating frequencies: 2.4 GHz, 5 GHz
Bluetooth Bluetooth Core Specification Version 5.0
Classic Bluetooth and Low Energy Bluetooth (BLE)
Temperature range Normal operating temperature: 0 ~ +70 °C
Storage temperature: -40 ~ +90 °C
Power supply requirements Powered via USB Type-C, recommended to use a 18 W power adapter supporting PD protocol
Shield cover None
Firmware upgrade USB0
OTA
RoHS All components fully compliant with EU RoHS standards
Note: The Micro HDMI and MIPI display interfaces are mutually exclusive and cannot be used simultaneously.
Functional block diagram
Interface description
Detailed interface diagram
Interface description table
No. Interface name Description
1 2 × 20 Pin headers GPIO with multiple multiplexing functions, can be multiplexed as I2C, SPI, etc.
2 SD card interface SD + Nano SIM 2-in-1 socket, SD 3.0 protocol
2 (U)SIM card interface SD + Nano SIM 2-in-1 socket, 1.8/2.95 V (U)SIM card
3 eSIM card interface eSIM (MFF2) flip-lid socket, 1.8/2.95 V eSIM
4 DSI display interface One channel 4-lane MIPI DSI, data rate up to 1.5 Gbps/lane, based on MIPI standard FHD+ (1080 × 2520) @ 60 fps*
5 PWRKEY button Power on/off button
6 USB Type-C power Provides DC power via USB Type-C, supports PD
7 USB Type-C USB 3.0 Type-C interface
8 MEMS input MEMS microphone
9 Micro HDMI interface Micro HDMI video output interface, 1080P @ 60 Hz
10 Camera interface Two channels 4-lane MIPI CSI, data rate up to 2.5 Gbps/lane
11 POE interface 2 × 2 Pins headers, POE power output
12 Ethernet interface 10/100/1000 Mbps Ethernet
13 USB Type-A 3.0 Two standard USB 3.0 Type-A interfaces
14 USB Type-A 2.0 Two standard USB 2.0 Type-A interfaces
15 DBG interface 1 × 3 Pins header
16 ADC interface SH1.0-4P interface, two-channel ADC input, input voltage range from 0 ~ 5.0 V
17 Audio in/out interface SH1.0-4P interface, audio input/output
18 GNSS antenna interface IPEX-4TH test connector
19 Diversity antenna interface IPEX-4TH test connector
20 Main antenna interface IPEX-4TH test connector
21 Wi-Fi/Bluetooth antenna interface IPEX-4TH test connector
22 PWRKEY button Power on/off button
23 USB Type-C power Provides DC power via USB Type-C, supports PD
24 ADC interface SH1.0-4P interface, two-channel ADC input, input voltage range from 0 ~ 5.0 V
25 POE interface 2 × 2 Pins headers, POE power output
26 DBG interface 1 × 3 Pins header
40-pin connector definition
The following is the list of definitions for the 2 × 20-pin connector:
Pin no. Pin name Pin no. Pin name
1 VCC_3V3 2 VCC_5V
3 GPIO_14 4 VCC_5V
5 GPIO_15 6 GND
7 GPIO_83 8 GPIO_69
9 GND 10 GPIO_70
11 GPIO_106 12 GPIO_98
13 GPIO_31 14 GND
15 GPIO_71 16 GPIO_84
17 VCC_3V3 18 GPIO_25
19 GPIO_1 20 GND
21 GPIO_0 22 GPIO_80
23 GPIO_2 24 GPIO_3
25 GND 26 GPIO_82
27 GPIO_109 28 GPIO_110
29 GPIO_5 30 GND
31 GPIO_4 32 GPIO_67
33 GPIO8 34 GND
35 GPIO_99 36 GPIO_16
37 GPIO_17 38 GPIO_101
39 GND 40 GPIO_100
Camera pin definitions
The following is the list of definitions for Camera 1 22-pin connector:
1 GND 2 MIPI_CSI0_LN0N
3 MIPI_CSI0_LN0P 4 GND
5 MIPI_CSI0_LN1N 6 MIPI_CSI0_LN1P
7 GND 8 MIPI_CSI0_CLKN
9 MIPI_CSI0_CLKP 10 GND
11 MIPI_CSI0_LN2N 12 MIPI_CSI0_LN2P
13 GND 14 MIPI_CSI0_LN3N
15 MIPI_CSI0_LN3P 16 GND
17 CAM_PWDN_1 18 CAM0_MCLK
19 GND 20 CAM_I2C_SCL0_0
21 CAM_I2C_SDA0_0 22 VDD_3V3_CAM1
The following is the list of definitions for Camera 2 22-pin connector:
19 GND 20 CAM_I2C_SCL1_1
21 CAM_I2C_SDA1_1 22 VDD_3V3_CAM2
Display pin definitions
The following is the list of definitions for Display 22-pin connector:
1 GND 2 MIPI_DSI_LN0N
3 MIPI_DSI_LN0P 4 GND
5 MIPI_DSI_LN1N 6 MIPI_DSI_LN1P
7 GND 8 MIPI_DSI_CLKN
9 MIPI_DSI_CLKP 10 GND
11 MIPI_DSI_LN2N 12 MIPI_DSI_LN2P
13 GND 14 MIPI_DSI_LN3N
15 MIPI_DSI_LN3P 16 GND
17 LCM_RST_1 18 LCM_INT_1
19 GND 20 TP_I2C_SCL1
21 TP_I2C_SDA1 22 VDD_3V3_LCM1
Mechanical dimensions
This section mainly introduces the mechanical dimensions of the product. All dimension units are in mm. For all dimensions without specified tolerances, the tolerance is +0.10/-0.15.
Electrical characteristics
Absolute maximum ratings
Parameter Minimum value Maximum value Unit
USB Type-C supply voltage -0.3 20.0 V
Digital pin voltage of expansion interface -0.3 3.6 V
Note: Exceeding the operating conditions shown in the above table may cause permanent damage to the product.
Power supply ratings
The product can be powered through the POWER IN Type-C port, supporting USB PD 3.0 fast charging protocol. The power supply for the product should be able to provide 5 V/5 A or higher power supply.
Digital logic level characteristics
2 × 20-pin I/O requirements (Unit: V)
Parameter Description Minimum value Maximum value
VIH Input high level 2.81 3.30
VIL Input low level 0 0.66
VOH Output high level 3.00 3.30
VOL Output low level 0 0.30
ESD protection
Static electricity generated by sources such as the human body and friction between microelectronics can discharge into the product through various pathways, potentially causing damage. Therefore, attention must be paid to ESD protection, and reasonable precautionary measures should be taken. For example: Wear anti-static gloves during R&D, production, assembly, and testing processes; during product design, add ESD protection components at circuit interfaces and other points vulnerable to electrostatic discharge. ESD withstand voltage (temperature: 25 ~ 30°C, humidity: 40 ± 5 %; unit: kV).
Test point Contact discharge Air discharge
VBAT and GND – –
Other interfaces – –
Operating and storage temperature
Operating and storage temperature (Unit: ℃)
Parameter Minimum value Typical value Maximum value
Normal operating temperature 0 +25 +70
Storage temperature -30 – +90
