Edge Computing Playground
Edge Computing Playground User Experience Platform is designed to provide industry users with an "out-of-the-box" integrated software and hardware Edge Computing experience. Whether for individual developers or enterprise innovation teams, Edge Computing Playground offers full-chain support, enabling complex Edge Computing technology to be efficiently transformed into practical implementation paths, accelerating Edge Computing innovation and productization.
Edge Computing Playground Introduction
This section mainly introduces the integration development guide for Edge Computing Playground User Experience Platform for Android-side algorithm SDK, aimed at helping developers quickly understand and deploy various Edge Computing algorithms.
Integrated Algorithm Services
| Algorithm Type | Function Description | Application Scenarios |
| Face Recognition | Face detection, keypoint localization, feature extraction and comparison | Access control attendance, identity verification |
| Mask Detection | Detect mask wearing status (correct/incorrect/not worn) | Public place safety monitoring |
| Gesture Recognition | Recognize common gesture actions | Human-computer interaction, smart home |
| QR Code Recognition | Quickly scan and decode QR codes/barcodes | Payment, information retrieval |
| OCR Text Recognition | Text extraction from images and camera streams | ID card recognition, receipt processing |
Pre-deployment Preparation
Development Environment Requirements
| Item | Requirements |
| IDE | Android Studio Arctic Fox (2020.3.1) or higher |
| Android SDK | compileSdk 32 |
| Android NDK | 21.4.7075529 |
| CMake | 3.22.1 |
| Gradle | 7.0+ |
| JDK | 1.8 |
| Target Device | ARM64 architecture (arm64-v8a) |
| Minimum System Version | Android 5.0 (API 21) |
| Target System Version | Android 11 (API 30) |
Note: The device needs to be connected to adb tools first, execute adb root, then execute adb shell setenforce 0
Required Software Installation
Android Studio Configuration
1. Install NDK and CMake
Open Android Studio → Settings → Appearance & Behavior → System Settings → Android SDK
- Switch to SDK Tools tab
Check and install the following components:
- NDK (Side by side) → Select version 21.4.7075529
- CMake → Select version 3.22.1
- Android SDK Build-Tools
- Android SDK Platform-Tools
2. Configure Environment Variables (Windows System)
ANDROID_NDK_HOME = C:\Users\[Username]\AppData\Local\Android\Sdk\ndk\21.4.7075529
Gradle Configuration
Project root directory build.gradle:
plugins {
alias(libs.plugins.android.application) apply false
alias(libs.plugins.kotlin.android) apply false
Project Dependencies
Java/Kotlin Dependencies
Native Libraries (.so files)
The project depends on the following pre-compiled Native libraries (contact us on official website), which need to be placed in the app/src/main/jniLibs/arm64-v8a/ directory:
| Library Name | Description |
| libedge_computingmarket.so | Main algorithm library (project build output) |
| libinference.so | Inference engine |
| libopencv_java4.so | OpenCV image processing library |
| libfacerecognition.so | Face recognition algorithm library |
| libmaskdet.so | Mask detection algorithm library |
| libpipeline.so | Gesture recognition pipeline library |
| libdeepocr.so | OCR text recognition library |
| libzbar.so | QR code recognition library |
| libzbar_ex.so | QR code extension library |
| libjsoncpp.so | JSON parsing library |
| libc++_shared.so | C++ runtime library |
Model File Deployment
Model files need to be deployed to the specified directory on the device, project default path structure:
/data/user/0/com.quectel.edgecomputingmarket/files/model/
├── face # Sub-module name
│ └── sim.engine # Sub-module model file
├── hand
│ └── sim.engine
├── person
│ └── sim.engine
└── reid
└── sim.engine
Model Core Information
Model Algorithm List
| No. | Algorithm Name | Model Type | Input Size | Hardware Acceleration | Description |
| 1 | Face Recognition | Recognition Model | 256×256 | DSP | Recognize faces in images |
| 2 | Mask Detection | Detection Model | 640×640 | DSP | Three categories: correct/incorrect/not worn |
| 3 | Gesture Detection | Detection Model | 640×640 | DSP | Detect gesture regions |
| 4 | OCR Text Recognition | Recognition Model | - | DSP | Text content recognition |
| 5 | QR Code Recognition | Decoding Algorithm | - | CPU | Supports QR Code and other code formats |
Detailed Algorithm Descriptions
Face Recognition
Functional Modules:
- Face Detection: Locate face positions in images/video streams, output bounding box coordinates
- Keypoint Localization: Extract 5 facial keypoints (left eye, right eye, nose tip, left mouth corner, right mouth corner)
- Feature Extraction: Generate 128-dimensional face feature vectors
- Face Comparison: Calculate face similarity through cosine similarity
Technical Parameters:
| Parameter | Value |
| Detection confidence threshold | 0.5 |
| NMS threshold | 0.5 |
| Minimum face area ratio | 1% (image area) |
| Feature dimension | 128-dimensional |
| Similarity threshold | 0.6 |
Mask Detection
Detection Categories:
| Category ID | Category Name | Description |
| 0 | Correctly_Worn | Correctly wearing mask |
| 1 | Not_Worn | Not wearing mask |
| 2 | Incorrectly_Worn | Incorrectly wearing mask (covering mouth only/nose only, etc.) |
| Parameter | Default Value |
| Confidence threshold | 0.25 |
| NMS threshold | 0.45 |
| Minimum detection box area | 1% (image area) |
Gesture Recognition
Supported Gesture Types:
| No. | Gesture Name | Description |
| 1 | like | Thumbs up gesture |
| 2 | dislike | Thumbs down gesture |
| 3 | call | Phone call gesture |
| 4 | fist | Fist gesture |
| 5 | four | Four fingers gesture |
| 6 | mute | Mute gesture |
| 7 | ok | OK gesture |
| 8 | one | Index finger gesture |
| 9 | palm | Open palm |
| 10 | other | Other gestures |
| 11 | three | Three fingers gesture |
| 12 | yeah | Victory/V gesture |
Pipeline Process: Detection → Cropping → Classification
Functional Features:
- Supports multi-line text detection
- Automatically recognizes mixed Chinese-English text
- Returns text content and position information
| Parameter | Value |
| Confidence threshold | 0.2 |
| Input size | 256×256 |
| Supported languages | Chinese, English |
QR Code Recognition
Supported Code Formats:
- QR Code
- EAN-13 (configurable to disable)
- Other ZBar-supported code formats
Configuration Parameters:
g_qrScanner->set_config(ZBAR_QRCODE, ZBAR_CFG_X_DENSITY, 4);
g_qrScanner->set_config(ZBAR_QRCODE, ZBAR_CFG_Y_DENSITY, 4);
Model Migration Process (Face Recognition Example)
This section takes face recognition as an example to introduce in detail how to integrate algorithm models from scratch in Android Studio.
Project Structure Creation
app/src/main/
├── cpp/
│ ├── CMakeLists.txt # CMake configuration file
│ ├── edge_computing_market.cpp # JNI interface implementation
│ └── include/ # Header file directory
│ ├── faceRecogInterfaceEX.hpp
│ ├── SNPEClass.hpp
├── java/com/quectel/edgecomputingmarket/
│ └── manager/
│ └── JniManager.java # JNI management class
├── jniLibs/arm64-v8a/ # Native library directory
│ ├── libSNPE.so
│ ├── libopencv_java4.so
└── assets/models/
└── face_model/
└── sim.engine
CMake Configuration
Create app/src/main/cpp/CMakeLists.txt:
cmake_minimum_required(VERSION 3.22.1)
project("edge_computing_market" LANGUAGES CXX)
# ========== Path Configuration ==========
set(THIRD_PARTY_SO_ROOT "${CMAKE_SOURCE_DIR}/../jniLibs")
set(INCLUDE_ROOT "${CMAKE_SOURCE_DIR}/include")
set(LOCAL_SRC_DIR "${CMAKE_SOURCE_DIR}")
set(SUPPORTED_ABI "arm64-v8a")
set(THIRD_PARTY_SO_DIR "${THIRD_PARTY_SO_ROOT}/${SUPPORTED_ABI}")
# ========== Import Pre-compiled Libraries ==========
# OpenCV library
set(OPENCV_LIB_NAME "opencv_java4")
add_library(${OPENCV_LIB_NAME} SHARED IMPORTED)
set_target_properties(${OPENCV_LIB_NAME} PROPERTIES
IMPORTED_LOCATION "${THIRD_PARTY_SO_DIR}/lib${OPENCV_LIB_NAME}.so"
# SNPE inference engine
set(SNPE_LIB_NAME "SNPE")
add_library(${SNPE_LIB_NAME} SHARED IMPORTED)
set_target_properties(${SNPE_LIB_NAME} PROPERTIES
IMPORTED_LOCATION "${THIRD_PARTY_SO_DIR}/lib${SNPE_LIB_NAME}.so"
# C++ runtime
set(C_SHARED_LIB_NAME "c++_shared")
add_library(${C_SHARED_LIB_NAME} SHARED IMPORTED)
set_target_properties(${C_SHARED_LIB_NAME} PROPERTIES
IMPORTED_LOCATION "${THIRD_PARTY_SO_DIR}/lib${C_SHARED_LIB_NAME}.so"
# Face recognition library
set(FACE_LIB_NAME "facerecognition")
add_library(${FACE_LIB_NAME} SHARED IMPORTED)
set_target_properties(${FACE_LIB_NAME} PROPERTIES
IMPORTED_LOCATION "${THIRD_PARTY_SO_DIR}/lib${FACE_LIB_NAME}.so"
# ========== Header File Configuration ==========
function(recursive_include dir)
if(IS_DIRECTORY ${dir})
include_directories(${dir})
file(GLOB SUB_DIRS RELATIVE ${dir} "${dir}/*")
foreach(sub_dir ${SUB_DIRS})
set(full_sub_dir "${dir}/${sub_dir}")
if(IS_DIRECTORY ${full_sub_dir})
recursive_include(${full_sub_dir})
endif()
endforeach()
endif()
endfunction()
recursive_include(${INCLUDE_ROOT})
# ========== Build edge_computing_market.so ==========
file(GLOB LOCAL_SRC_FILES
"${LOCAL_SRC_DIR}/edge_computing_market.cpp"
find_library(LOG_LIB log REQUIRED)
find_library(JNI_GRAPHICS_LIB jnigraphics REQUIRED)
add_library(edge_computing_market SHARED ${LOCAL_SRC_FILES})
target_compile_features(edge_computing_market PRIVATE cxx_std_17)
target_compile_options(edge_computing_market PRIVATE
-frtti
-fexceptions
-Wno-error=format-security
-fPIC
target_link_libraries(edge_computing_market PRIVATE
${FACE_LIB_NAME}
${OPENCV_LIB_NAME}
${SNPE_LIB_NAME}
${JNI_GRAPHICS_LIB}
${LOG_LIB}
c m dl atomic
JNI Interface Layer Implementation
Java Layer Interface Definition
Create JniManager.java:
package com.quectel.edgecomputingmarket.manager;
public class JniManager {
private static final String TAG = "JniManager";
private static final String SO_NAME = "edge_computing_market";
private static volatile JniManager INSTANCE;
private static boolean isSoLoaded = false;
// Load Native library
static {
try {
System.loadLibrary(SO_NAME);
isSoLoaded = true;
} catch (UnsatisfiedLinkError e) {
isSoLoaded = false;
// Singleton pattern
public static JniManager getInstance() {
if (INSTANCE == null) {
synchronized (JniManager.class) {
INSTANCE = new JniManager();
return INSTANCE;
// ========== Face Recognition Interface ==========
* Set SNPE environment variable
* @param soPath Native library path
public native void setAdspEnv(String soPath);
* Initialize face recognition model
* @param faceDetModelPath Face detection model path
* @param faceLandmarkModelPath Keypoint model path
* @param faceRegModelPath Feature extraction model path
* @param faceDbPath Face database path
* @return 0-success, negative value-error code
public native int initFaceRecognition(
String faceDetModelPath,
String faceLandmarkModelPath,
String faceRegModelPath,
String faceDbPath
* Face recognition from image
* @param imagePath Input image path
* @param saveDir Result image save directory
* @return Result image path
public native String faceRecognitionFromImage(String imagePath, String saveDir);
* Real-time face recognition from camera stream
* @param mergedYuvData YUV data
* @param width Image width
* @param height Image height
* @param rotation Rotation angle
* @return Detection result array [face count, x, y, w, h, id, score, keypoint count, keypoint coordinates...]
public native float[] faceRecognitionFromCameraX(
byte[] mergedYuvData,
int width,
int height,
int rotation
* Release face recognition resources
public native void releaseCameraFaceRecog();
C++ Layer JNI Implementation
Create edge_computing_market.cpp (core code snippet):
#include <jni.h>
#include <string>
#include <vector>
#include <android/log.h>
#include "faceRecogInterfaceEX.hpp"
#include "opencv2/opencv.hpp"
#define LOG_TAG "JNI_edge_computing_market"
#define LOGD(...) __android_log_print(ANDROID_LOG_DEBUG, LOG_TAG, __VA_ARGS__)
#define LOGE(...) __android_log_print(ANDROID_LOG_ERROR, LOG_TAG, __VA_ARGS__)
// Global face recognition instance
static std::unique_ptr<FaceRecogInterFaceEX::FaceRecogIFEX> g_frIfEx = nullptr;
static std::vector<std::vector<float>> g_faceFeatures;
static int g_validFeatureDim = 0;
void SetAdspLibraryPath(const std::string &nativeLibPath) {
std::stringstream spath;
std::stringstream spath1;
spath << nativeLibPath << ";/vendor/lib/rfsa/adsp;/vendor/dsp;/vendor/dsp/cdsp";
spath1 << nativeLibPath;
LOGD("nativeLibPath is %s", nativeLibPath.c_str());
if (setenv("ADSP_LIBRARY_PATH", spath.str().c_str(), 1 /*override*/) == 0) {
LOGD("SNPE environment configured successfully");
} else {
LOGD("SNPE environment configuration failed");
if (setenv("LD_LIBRARY_PATH", spath1.str().c_str(), 1 /*override*/) == 0) {
} else {
LOGD("ADSP_LIBRARY_PATH is %s", getenv("ADSP_LIBRARY_PATH"));
LOGD("LD_LIBRARY_PATH is %s", getenv("LD_LIBRARY_PATH"));
extern "C" JNIEXPORT void JNICALL
Java_com_quectel_edgecomputingmarket_manager_JniManager_setAdspEnv(
JNIEnv *env,
jobject thiz,
jstring soLibraryPath
const char *ldPath = env->GetStringUTFChars(soLibraryPath, nullptr);
if (ldPath == nullptr) {
LOGE("Environment variable path is empty!");
goto end;
SetAdspLibraryPath(ldPath);
end:
env->ReleaseStringUTFChars(soLibraryPath, ldPath);
extern "C"
JNIEXPORT jint JNICALL
Java_com_quectel_edgecomputingmarket_manager_JniManager_initFaceRecognition(
JNIEnv *env, jobject thiz,
jstring face_det_model_path,
jstring face_landmark_model_path,
jstring face_reg_model_path,
jstring face_db_path) {
try {
if (g_frIfEx != nullptr) {
LOGD("Face recognition already initialized");
// Get model paths
char *detModel = const_cast<char *>(env->GetStringUTFChars(face_det_model_path, nullptr));
char *landmarkModel = const_cast<char *>(env->GetStringUTFChars(face_landmark_model_path, nullptr));
char *regModel = const_cast<char *>(env->GetStringUTFChars(face_reg_model_path, nullptr));
char *dbPath = const_cast<char *>(env->GetStringUTFChars(face_db_path, nullptr));
// Create face recognition instance
g_frIfEx = std::make_unique<FaceRecogInterFaceEX::FaceRecogIFEX>(
detModel, landmarkModel, regModel);
int err = g_frIfEx->init();
if (err != 0) {
g_frIfEx.reset();
return err;
// Load face database
std::vector<std::string> filePaths;
glob(dbPath, filePaths);
g_faceFeatures.clear();
for (const auto &path: filePaths) {
cv::Mat img = cv::imread(path);
if (img.empty()) continue;
std::vector<FaceRecogInterFaceEX::FaceResults_t> faceResults;
err = g_frIfEx->detect_face(img, faceResults, 0.5, 0.5);
if (err == 1 && !faceResults.empty() && !faceResults[0].feature.empty()) {
g_faceFeatures.emplace_back(faceResults[0].feature);
g_validFeatureDim = faceResults[0].feature.size();
// Release string resources
env->ReleaseStringUTFChars(face_det_model_path, detModel);
env->ReleaseStringUTFChars(face_landmark_model_path, landmarkModel);
env->ReleaseStringUTFChars(face_reg_model_path, regModel);
env->ReleaseStringUTFChars(face_db_path, dbPath);
return g_faceFeatures.empty() ? -2 : 0;
} catch (...) {
return -5;
* Camera stream face recognition
extern "C"
JNIEXPORT jfloatArray JNICALL
Java_com_quectel_edgecomputingmarket_manager_JniManager_faceRecognitionFromCameraX(
jbyteArray mergedYuvData_,
jint width, jint height, jint rotation) {
if (g_frIfEx == nullptr || g_faceFeatures.empty()) {
jfloatArray emptyArray = env->NewFloatArray(1);
float emptyVal = 0.0f;
env->SetFloatArrayRegion(emptyArray, 0, 1, &emptyVal);
return emptyArray;
// Get YUV data
jbyte *mergedYuvData = env->GetByteArrayElements(mergedYuvData_, nullptr);
// YUV to BGR
cv::Mat yuvMat(height * 3 / 2, width, CV_8UC1, (unsigned char *) mergedYuvData);
cv::Mat bgrMat;
cv::cvtColor(yuvMat, bgrMat, cv::COLOR_YUV2BGR_I420);
// Image rotation
cv::Mat rotatedMat;
switch (rotation) {
case 90: cv::rotate(bgrMat, rotatedMat, cv::ROTATE_90_CLOCKWISE); break;
case 180: cv::rotate(bgrMat, rotatedMat, cv::ROTATE_180); break;
case 270: cv::rotate(bgrMat, rotatedMat, cv::ROTATE_90_COUNTERCLOCKWISE); break;
default: rotatedMat = bgrMat.clone(); break;
// Face detection
g_frIfEx->detect_face(rotatedMat, faceResults, 0.5f, 0.5f);
// Feature matching
for (auto &face: faceResults) {
if (!face.feature.empty() && face.feature.size() == g_validFeatureDim) {
std::pair<int, float> matchRes = g_frIfEx->cosine_similarity(
g_faceFeatures, face.feature, 0.6f);
face.code = matchRes.first;
// Build return result
int resultSize = 1;
for (const auto &face: faceResults) {
resultSize += 7 + face.key_pts.size() * 2;
jfloatArray resultArray = env->NewFloatArray(resultSize);
std::unique_ptr<float[]> resultData(new float[resultSize]);
int idx = 0;
resultData[idx++] = static_cast<float>(faceResults.size());
resultData[idx++] = static_cast<float>(face.x);
resultData[idx++] = static_cast<float>(face.y);
resultData[idx++] = static_cast<float>(face.width);
resultData[idx++] = static_cast<float>(face.height);
resultData[idx++] = static_cast<float>(face.code);
resultData[idx++] = 0.0f; // score
resultData[idx++] = static_cast<float>(face.key_pts.size());
for (const auto &pt: face.key_pts) {
resultData[idx++] = static_cast<float>(pt.x);
resultData[idx++] = static_cast<float>(pt.y);
env->SetFloatArrayRegion(resultArray, 0, resultSize, resultData.get());
env->ReleaseByteArrayElements(mergedYuvData_, mergedYuvData, JNI_ABORT);
return resultArray;
* Release resources
extern "C"
Java_com_quectel_edgecomputingmarket_manager_JniManager_releaseCameraFaceRecog(
JNIEnv *env, jobject thiz) {
g_frIfEx.reset();
build.gradle Configuration
Add the following in app/build.gradle:
android {
// ... other configurations ...
defaultConfig {
externalNativeBuild {
cmake {
cppFlags ""
abiFilters 'arm64-v8a'
ndk {
cmake {
path "src/main/cpp/CMakeLists.txt"
version "3.22.1"
ndkVersion '21.4.7075529'
Usage Examples
Model Initialization
public class MainActivity extends AppCompatActivity {
private JniManager jniManager;
@Override
protected void onCreate(Bundle savedInstanceState) {
super.onCreate(savedInstanceState);
// Get JNI manager instance
jniManager = JniManager.getInstance();
// Set SNPE environment
String nativeLibDir = getApplicationInfo().nativeLibraryDir;
jniManager.setAdspEnv(nativeLibDir);
// Initialize face recognition
String modelPath = getFilesDir() + "/model/face_model";
String faceDbPath = getFilesDir() + "/model/facedb";
int result = jniManager.initFaceRecognition(// pass model file paths as parameters);
if (result == 0) {
Log.d("EdgeComputingMarket", "Face recognition initialized successfully");
} else {
Log.e("EdgeComputingMarket", "Face recognition initialization failed: " + result);
Camera Stream Face Recognition
Using CameraX as example, requires importing relevant dependencies, you can also choose other camera implementation methods:
// Use CameraX to get preview frames
previewView.getPreviewStreamState().observe(this, state -> {
// Camera ready
// Process frame data in ImageAnalysis
ImageAnalysis imageAnalysis = new ImageAnalysis.Builder()
.setTargetResolution(new Size(640, 480))
.setBackpressureStrategy(ImageAnalysis.STRATEGY_KEEP_ONLY_LATEST)
.build();
imageAnalysis.setAnalyzer(executor, image -> {
// Get YUV data
ImageProxy imageProxy = image;
byte[] yuvData = yuv420ToNv21(imageProxy);
// Call face recognition
float[] results = jniManager.faceRecognitionFromCameraX(
yuvData,
imageProxy.getWidth(),
imageProxy.getHeight(),
getRotationDegrees()
// Parse results
if (results != null && results.length > 1) {
int faceCount = (int) results[0];
int idx = 1;
for (int i = 0; i < faceCount; i++) {
float x = results[idx++];
float y = results[idx++];
float w = results[idx++];
float h = results[idx++];
int id = (int) results[idx++];
// Skip score and keypoints
idx += 2 + (int) results[idx - 1] * 2;
Log.d("FaceResult", "Face " + i + ": pos=(" + x + "," + y +
"), id=" + id);
image.close();
Resource Release
@Override
protected void onDestroy() {
super.onDestroy();
if (jniManager != null) {
jniManager.releaseCameraFaceRecog();
Demo Demonstration
Select the desired function from the left tab. Local Picture is for selecting local images for recognition, Live Camera is for invoking the device camera for recognition, APM is for viewing device performance changes and runtime logs.
Select Local Picture, click the gray area in the Before region to upload an image.
Select Live Camera, click Start Camera to begin camera recognition.
Common Troubleshooting
Note: This project requires the use of system libraries, ensure targetSdk ≤ 30. Before installing the application, you need to connect to the device via adb and execute adb root command, then execute adb shell setenforce 0 command. Also, the ADSP environment variable must be set before initializing the algorithm's .so library for normal operation. Refer to the code above.
| Problem | Possible Cause | Solution |
| Algorithm validity expired | Algorithm has a one-hour validity period after initialization, will expire after timeout | Exit current application and clear background to restart |
| UnsatisfiedLinkError | .so library not loaded correctly | Check jniLibs directory structure and architecture match, and whether environment variables are set |
| Model initialization failed (-1) | Model file does not exist or path error | Check if model files are correctly copied to device |
| Face database loading failed (-2) | Face database image format incorrect | Ensure using standard JPEG format images |
| Detection result is empty | Image format or size incorrect, some cameras have unfixed angles causing rotation/mirroring issues in captured images | Check YUV data format and rotation angle, correctly rotate input images |
| DSP unavailable | Device does not support SNPE DSP | Replace device |
