Quecpi_config User Guide
quecpi_config is a tool for configuring Quectel Pi H1, providing the following functions:
  1. Configure onboard LED working mode and brightness
  2. Configure fan interface working mode and fan speed
  3. Configure 40pin interface working mode
  4. Query the temperature of various system components
  5. Query system CPU, memory and storage status
  6. Configure WiFi
Onboard LED Configuration
Configure working mode
quecpi_config led mode <blue|green|red> <heartbeat|none>
Configure brightness
quecpi_config led brightness <blue|green|red> <0-511>
Fan Configuration
Configure fan speed
quecpi_config fan set speed <0-255>
40pin Interface Working Mode Configuration
First modify the configuration file /etc/quecpi_config/quecpi_config.ini, then run the following command to configure
quecpi_config 40pin set
Query Temperature of Various System Components
quecpi_config dump temperature
Query System CPU, Memory and Storage Usage
quecpi_config dump systemusage
Configure WiFi
Scan for WiFi
quecpi_config wifi scan
View existing WiFi connections
quecpi_config wifi show
View WiFi connection status
quecpi_config wifi dump <connection uuid>
Add a WiFi connection
quecpi_config wifi connect <ssid> <password>
Delete a WiFi connection
quecpi_config wifi delete <connection uuid>
