NVMe SSD Partitioning, Formatting, and Mounting Documentation
This document describes the complete process of partitioning, formatting, mounting, and performance testing an NVMe solid-state drive (using /dev/nvme0n1 as an example) in a Linux system, applicable to Quectel Pi H1.
Partitioning Operations (Using fdisk)
Partition the NVMe device using the fdisk tool with the following steps:
Enter the Partitioning Interactive Interface
Execute the following command to launch fdisk and specify the target NVMe device:
fdisk /dev/nvme0n1
Interactive Interface Operation Steps
After entering fdisk interactive mode, execute commands in the following order:
Create a GPT Partition Table
Enter g and press Enter to create a GUID Partition Table (GPT), suitable for large-capacity devices (recommended):
Command (m for help): g
Create a New Partition
Enter n and press Enter to create a new partition. Keep the subsequent parameters (partition number, start sector, end sector) as default (the entire available space will be used by default):
Command (m for help): n
Write the Partition Table and Exit
Enter w and press Enter to write the partition configuration to the device and exit fdisk:
Command (m for help): w
Syncing disks.
After completion, the system will generate a new partition /dev/nvme0n1p1 (where p1 indicates the first partition).
Formatting the Partition (EXT4 Format)
Use the mkfs.ext4 tool to format the new partition into the EXT4 file system (suitable for most Linux environments):
mkfs.ext4 /dev/nvme0n1p1
After execution, the formatting progress will be displayed, and similar information will be output upon completion:
mke2fs 1.46.5 (30-Dec-2021)
32768, 98304, 163840, ...
Allocating group tables: done
Writing inode tables: done
Manually Mounting the Partition
Create a Mount Directory
Use the mkdir command to create a directory for mounting the SSD (example path: /mnt/myssd):
mkdir -p /mnt/myssd
Mount the Partition
Mount the /dev/nvme0n1p1 partition to the /mnt/myssd directory:
You can verify the mounting success using the df -h command. If the output contains /dev/nvme0n1p1 and /mnt/myssd, the mounting is normal:
df -h
/dev/nvme0n1p1 100G 5G 95G 5% /mnt/myssd
Configuring Automatic Mounting (Effective After Reboot)
Implement automatic mounting of the partition during system startup by modifying the /etc/fstab file:
Edit the fstab File
Open /etc/fstab using the nano editor (other editors like vim can also be used):
Add Mount Configuration
Add the following line at the end of the file to specify the partition, mount point, file system type, and mount parameters:
/dev/nvme0n1p1 /mnt/myssd ext4 defaults 0 2
Performance Testing (Read/Write Speed Verification)
Use the dd command to test the read/write performance of the SSD (ensure the partition is mounted during testing):
Read Speed Test
Create a temporary test file (if it already exists) and test the read speed by reading the file to the null device (/dev/null):
1+0 records in
1+0 records out
Write Speed Test
Generate a 1GB empty file (/dev/zero as the source of zero data) to test the write speed:
1+0 records in
1+0 records out
After testing, you can delete the temporary file:
rm /mnt/myssd/testfile
