USB Camera Test
The QuecPi Alpha single board computer supports USB interface cameras. Below, we will select a OV5693 5MP USB interface camera from Weixue as an example for testing.
Camera connection
Insert the USB camera cable into the Type-A interface of QuecPi Alpha.
View relevant information
- Run the following command in the SSH terminal to view the USB device information recognized by the system:
dmesg | grep usb
- Run the following command in the SSH terminal to view the newly added device nodes:
v4l2-ctl --list-devices
- /dev/video2 - Main video node, the gst command later mainly operates on this node
- /dev/video3 - Metadata node
- /dev/media3 - Hardware topology controller that controls the entire pipeline
- Run the following command in the SSH terminal to view the formats supported by the video node:
v4l2-ctl --list-formats-ext --device /dev/video2
- As shown in the figure, the camera supports image output in both MJPG and YUYV formats.
Preconditions
Connect the HDMI screen and run the following command in the SSH terminal:
mount -o rw,remount /
Real time preview
- Run the following command in the device terminal:
#MJPG format, resolution and frame rate should correspond to the formats supported by the video node
gst-launch-1.0 v4l2src device=/dev/video2 ! image/jpeg,width=1280,height=720,framerate=30/1 ! jpegdec ! videoconvert ! waylandsink fullscreen=true
#YUV format, resolution and frame rate should correspond to the formats supported by the video node
gst-launch-1.0 v4l2src device=/dev/video2 ! video/x-raw,format=YUY2,width=1280,height=720,framerate=10/1 ! videoconvert ! waylandsink fullscreen=true
Command Description:
- gst-launch-1.0 -e
Start the pipeline; -e Ensure that when pressing Ctrl+C to stop, it will end correctly (EOS).
- v4l2src device=/dev/video2
Collect data from V4L2 device /dev/video2.
- image/jpeg,width=1280,height=720,framerate=30/1
Require the camera to output 1280x720@30 fps MJPEG; If the camera does not support it, the pipeline will directly report an error.
- jpegdec
Decode MJPEG frames into raw YUV/RGB pixel data.
- videoconvert
Convert the pixel format to a format that Waylandink can accept (usually NV12/BGRx).
- waylandsink fullscreen=true
Use Wayland as the display backend and set the window to full screen (no title bar, full screen).
Preview + Video Recording
gst-launch-1.0 -e v4l2src device=/dev/video2 io-mode=2 ! \
image/jpeg,width=1280,height=720,framerate=30/1 ! \
jpegdec ! videoconvert ! tee name=t \
t. ! queue ! v4l2h264enc ! h264parse ! mp4mux ! filesink location=/opt/out.mp4 \
t. ! queue ! videoconvert ! waylandsink fullscreen=true sync=false
- This command starts the camera with 720p 30 FPS configuration and saves it as a video file after h264 video encoding. If the gst pipeline status changes to "PLAYING", it indicates that the camera is running.
- If you want to stop the camera recording, please press
CTRL+C. - MP4 files are saved in the /opt/ directory.
- v4l2src device=/dev/video2 io-mode=2
Capture video streams from /dev/video2 devices, with io mode=2 indicating the use of memory mapped (mmap) mode to improve performance.
The specified captured video stream format is MJPEG, with a resolution of 1280 × 720 and a frame rate of 30fps.
- jpegdec
Decode the video stream in MJPEG format and convert it to the original RGB/YUV format.
- videoconvert
Convert the decoded video format to a format suitable for subsequent processing (e.g. convert from YUV to RGBA).
- tee name=t
Split one video stream into two streams, which can be referenced later through t..
- t. ! queue
Extract a stream from the tee element and buffer it through the queue element.
- v4l2h264enc
Encode the video stream into H.264 format.
- h264parse
Analyze the H.264 encoded video stream to meet the requirements of the MP4 file format.
- mp4mux
Encapsulate H.264 video streams into MP4 file format.
- filesink location=/opt/out.mp4:
Save the packaged MP4 file to /opt/out. mp4.
- t. ! queue
Extract another stream from the tee element and buffer it through the queue element.
- videoconvert
Convert the video format to a format suitable for display on Wayland monitors.
- waylandsink fullscreen=true sync=false
Output the video stream to the Wayland monitor to display the video in full screen mode, disable sync mode, and avoid the Wayland monitor waiting for the data stream, thereby improving display performance.
- To play a video file, please run the following command in the device terminal:
gst-launch-1.0 -e filesrc location=/opt/out.mp4 ! qtdemux ! queue ! h264parse ! v4l2h264dec capture-io-mode=5 output-io-mode=5 ! videocrop top=0 bottom=40 left=0 right=0 ! videoconvert ! waylandsink fullscreen=true enable-last-sample=false
- filesrc location=/opt/out.mp4
Read data from the /opt/out.mp4 file.
- qtdemux
Separate the video and audio streams from the MP4 file.
- queue
Buffer data to avoid data loss during processing.
- h264parse
Analyze the H.264 encoded data in the video stream.
- v4l2h264dec capture-io-mode=5 output-io-mode=5
Use the V4L2 decoder to decode the H.264 video stream, where capture io mode=5 and output io mode=5 are hardware acceleration related parameters.
- videocrop top=0 bottom=40 left=0 right=0
Due to automatic alignment of video streams, additional pixel information is filled in. Resulting in a green edge at the bottom of the video, therefore cropping the bottom by 40 pixels.
- videoconvert
Format conversion elements ensure that the cropped video stream format is suitable for Wayland monitors.
- waylandsink fullscreen=true enable-last-sample=false
Output the decoded video to the Wayland monitor and set it to full screen mode, while disabling the display of the last frame.
Preview + Photo
tee name=t \
t. ! queue ! jpegdec ! videoconvert ! waylandsink sync=false \
t. ! queue ! multifilesink location=/opt/shot-%05d.jpg max-files=5
- Press
CTRL+Cto automatically save the last 5 images.
Collect MJPEG data from a USB camera.
Require the camera to output 1280x720@30 MJPEG stream with fps .
- tee name=t
Divide the same flow into multiple, and use t. to reference it later.
- t. ! queue ! jpegdec ! videoconvert ! waylandsink sync=false
Preview branch: decode MJPEG → convert to RGB → send to Wayland window for real-time display. Sync=false reduces latency.
- t. ! queue ! multifilesink location=shot-%05d.jpg max-files=5
Photography branch: Each frame is saved intact as JPG, and the file name is automatically numbered % 05d (5 digits). Max files=5 Only the most recent 5 files are retained, and old files are automatically deleted.
- To view photos, please enter the following command in the device terminal:
gst-launch-1.0 filesrc location=/opt/shot-00036.jpg ! jpegdec ! imagefreeze ! waylandsink fullscreen=true
- To exit the view, please press
CTRL+C.
- filesrc location=/opt/shot-00036.jpg
Read /opt/hot-00036. jpg from the file system.
- jpegdec
Decode JPEG compressed data into raw RGB/YUV pixel frames.
- imagefreeze
Keep only the first frame and repeat it continuously thereafter to achieve a 'still image' effect.
Send the image to the Wayland synthesizer for full screen display.
