Development Environment Setup
2025-07-02
Host Requirements
| Configuration | Tools |
| x86 computer | Git 1.8.3.1 or higher |
| Quad-core CPU, e.g., 3.4 GHz Intel i7-2600 (equivalent or higher) | Tar 1.28 or higher |
| 300 GB free disk space (Swap space > 32 GB) | Python 3.10.2 or higher |
| 16 GB RAM | GCC 7.5 or higher |
| Ubuntu 22.04 | GNU Make 4.0 or higher |
Tool Installation
Note: The Docker image has integrated the following environment tools. If you need to set up the environment using Docker, please ignore the following operation steps and visit Software Resources to obtain the Docker environment image.
Install the following packages to prepare the host environment for Yocto builds:
sudo apt install repo gawk wget git diffstat unzip texinfo gcc build-essential chrpath socat cpio python3 python3-pip python3-pexpect xz-utils debianutils iputils-ping python3-git python3-jinja2 libegl1-mesa libsdl1.2-dev pylint xterm python3-subunit mesa-common-dev zstd liblz4-tool locales tar python-is-python3 file libxml-opml-simplegen-perl vim whiptail g++
Set Locales (if not configured):
sudo locale-gen en_US.UTF-8
export LC_ALL=en_US.UTF-8
export LANG=en_US.UTF-8
Update Git Configuration
Check if identity is configured in .gitconfig:
git config --get user.email
git config --get user.name
If account identity is not set in .gitconfig, execute the following command:
Add the following UI color options for console output (optional):
Add the following Git configurations to get large repositories and avoid unreliable connections:
