Audio Testing
QuecPi Alpha single-board computer supports Audio external MIC recording, 3.5mm headphone recording, and 3.5mm headphone playback.
View Sound Card Information
- Enter the following command in the terminal to check the mounting status of the sound card:
- Enter the following command in the terminal to view the list of allocated PCM streams:
00-00: CODEC_DMA-LPAIF_RXTX-RX-0 multicodec-0 : : playback 1
00-01: CODEC_DMA-LPAIF_RXTX-TX-3 multicodec-1 : : capture 1
00-02: CODEC_DMA-LPAIF_VA-TX-0 va_macro_tx1-2 : : capture 1
External MIC Recording
1.To record using an external MIC, please enter the following command
pcm_plug_open: dlopen successful for libagm_pcm_plugin.so
Capturing sample: 1 ch, 48000 hz, 16 bit
diag: Diag_LSM_Init: invoked for pid: 1599 with init_count: 0
diag:successfully connected to socket 17
diag: Diag_LSM_Init: done for pid: 1599 with init_count: 1
diag: Successfully registered commands with the driver
- PulseAudio may occupy audio devices, causing direct hardware access (such as agmcp) to fail. After stopping, exclusive access can be ensured.
- -c 1 monaural recording
- -r 48000 sampling rate 48 kHz
- -b 16 sampling bit depth 16 bit
- -i "CODEC_DMA-LPAIF_VA-TX-0" specifies the input device interface as sending (recording) channel 0
2.If you want to stop recording, please press Ctrl+C to generate an audio file named test1.wav in the current directory
root@qcm6490-idp:/opt# ls
cni containerd test1.wav
3.5mm Earphone Recording
1.Before recording with 3.5mm headphones, the levels of gpio8 and gpio68 need to be set high
- gpio8------------Headphone national/American standard switching control switch, set to 0: European standard, set to 1: American standard
- gpio68-----------Headphone power supply enable switch, set 0: disable, set 1: enable
2.To record with 3.5mm headphones, please enter the following command
diag: Diag_LSM_Init: invoked for pid: 1384 with init_count: 0
diag: Diag_LSM_Init: done for pid: 1384 with init_count: 1
3.If you want to stop recording, please press Ctrl+C to generate an audio file named test2.wav in the current directory
cni containerd test2.wav
3.5mm Headphone Playback
- gpio8-------------Headphone national/American standard switching control switch, set to 0: European standard, set to 1: American standard
- gpio68------------Headphone power supply enable switch, set 0: disable, set 1: enable
2.To play with 3.5mm headphones, please enter the following command
- The audio will automatically stop after playing. If you want to stop it early, you can press Ctrl+C key
