Hardware Resources
2025-08-21
Feature | Parameter |
Processor | Qualcomm QCS6490 Octa-core 64-bit processor (12.15 TOPS AI compute) |
Memory | 8GB LPDDR4X |
Storage | 128GB UFS |
Power Supply | USB Type-C PD-compliant input, supports 27W PD adapter |
Wi-Fi/BT | 2.4GHz/5GHz Wi-Fi6E + BT5.2 module |
Ethernet | 1× Gigabit Ethernet port |
USB | 1× USB 3.0 Type-C interface (supports DP over Type-C & Audio over Type-C) 2× USB 2.0 Type-A interfaces |
Multimedia | 1× HDMI OUT display output 1× MIPI DSI display interface 2× MIPI CSI camera interfaces 1× 3.5mm audio jack (input/output) 1× Onboard DMIC |
Debug | 1× SH1.0 connector UART |
Buttons | 1× Power button 2× Custom buttons |
Status LED | 1× Power LED 1× Red LED 1× Blue LED 1× Green LED |
RPI Interface | 1× 40-pin Header (Raspberry Pi-compatible, supports GPIO/I2C/UART/SPI) |
RTC | Used for timing when power off |
SD Card Slot | 1× SD 3.0 (4-bit SDIO) |
PCIe Slot | 1× 1-lane PCIe 3.0 (up to 8 Gbps data rate) |
Other | Auto power-on switch 4-pin PWM fan interface |
