GPU Performance Testing
Background
In today's digital era, graphics processing capability has become one of the key metrics for evaluating the performance of the single-board computer. PI-SG565D, equipped with Qualcomm's Adreno 642L/643 GPU, demonstrates remarkable prowess in graphics processing. Imagine a smart traffic scenario where the PI-SG565D leverages its powerful GPU to rapidly and accurately identify and annotate target objects such as vehicles, license plates, and pedestrians, providing real-time and precise data for traffic management. In intelligent security applications, it can utilize the GPU's exceptional computational power to swiftly perform image recognition and analysis on complex surveillance footage, identifying potential risks in real time. Behind this efficient and precise graphics processing lies the PI-SG565D's robust GPU performance. It not only handles everyday multimedia tasks with ease but also excels in demanding applications requiring high-performance graphics computing. Here below is the evaluation of PI-SG565D's graphics rendering performance using the glmark2 benchmarking tool.
glmark2 is an open-source OpenGL ES and EGL benchmarking testing tool designed to assess device graphics rendering performance. It runs a series of standardized test scenarios (e.g., texture filling, lighting calculations, pixel processing) to quantify GPU metrics such as frame rate (FPS), latency (FrameTime), and stability. It is suitable for performance analysis and optimization on embedded devices, smartphones, and development boards.
Test Environment
glmark2 is integrated and installed in the system image by default. Entering the device terminal will test the GPU performance directly.
- Prepare a display and connect it to PI-SG565D.
Execute Commands
- Run the following command in the terminal to ensure results are displayed on the connected display:
- Execute the glmark2 command to test graphics rendering performance:
glmark2-es2-wayland
Test Results
QUALCOMM build : a4d6ce04e1, I363e8f8d61
Build Config : G ESX_C_COMPILER_OPT 4.4.0 AArch64
Driver Path : /usr/lib/libGLESv2_adreno.so
Driver Version : 0808.0
Process Name : glmark2-es2-wayland
Pre-rotation disabled !!!
EGL updater thread started
glmark2 2021.12
OpenGL Information
GL_VENDOR: Qualcomm
GL_RENDERER: Adreno (TM) 643
GL_VERSION: OpenGL ES 3.2
[bump] bump-render=normals:[ 606.705365][ T943] smcinvoke: process_accept_req: Setting pid:943, server id : 23 state to defunct
[ 606.714752][ T944] smcinvoke: process_accept_req: Setting pid:944, server id : 23 state to defunct
[ 606.724315][ T945] smcinvoke: process_accept_req: Setting pid:945, server id : 23 state to defunct
[ 606.734878][ T946] smcinvoke: process_accept_req: Setting pid:946, server id : 23 state to defunct
[ 606.751381][ T943] smcinvoke: process_tzcb_req: server is defunct, state= 1 tzhandle = -2147483625
[ 606.760794][ T943] smcinvoke: process_tzcb_req: server invalid, res: -90
FPS: 714 FrameTime: 1.401 ms
glmark2 Score: 506
EGL updater thread exited
Performance Analysis
The glmark2 benchmarking testing report indicates strong OpenGL ES graphics performance of PI-SG565D , with a final score of 506.
Key Performance Highlights
VBO (Vertex Buffer Object) Optimization:
- use-vbo=false → 516 FPS
- use-vbo=true → 679 FPS (31.6% improvement)
Conclusion: Enabling VBO significantly enhances rendering efficiency by reducing CPU-GPU data transfer overhead.
Texture Filtering Mode:
- Nearest → 748 FPS (fastest)
- Linear → 722 FPS (minor performance drop)
- Mipmap → 231 FPS (69% performance degradation)
Conclusion: Mipmap causes a significant drop in frame rate due to additional computational overhead, making it suitable for high-quality textures but at a significant performance cost.
Shading Mode:
- Blinn-phong-inf (optimized blinn-phong) → 679 FPS
- Cel (toon shading) → 688 FPS
- Phong/Gouraud (traditional mode) → ~220 FPS (lowest performance)
Conclusion: Modern shaders (e.g., blinn-phong-inf) outperform traditional mode (e.g., Phong) in efficiency.
