Quecpi_config User Guide
2025-08-22
quecpi_config is a tool for configuring PI-SG565D, providing the following functions:
- Configure onboard LED working mode and brightness
- Configure fan interface working mode and fan speed
- Configure 40pin interface working mode
- Query the temperature of various system components
- Query system CPU, memory and storage status
- Configure WiFi
Onboard LED Configuration
Configure working mode
quecpi_config led mode <blue|green|red> <heartbeat|none>
Configure brightness
quecpi_config led brightness <blue|green|red> <0-511>
Fan Configuration
Configure fan speed
quecpi_config fan set speed <0-255>
40pin Interface Working Mode Configuration
First modify the configuration file /etc/quecpi_config/quecpi_config.ini, then run the following command to configure
quecpi_config 40pin set
Query Temperature of Various System Components
quecpi_config dump temperature
Query System CPU, Memory and Storage Usage
quecpi_config dump systemusage
Configure WiFi
Scan for WiFi
quecpi_config wifi scan
View existing WiFi connections
quecpi_config wifi show
View WiFi connection status
quecpi_config wifi dump <connection uuid>
Add a WiFi connection
quecpi_config wifi connect <ssid> <password>
Delete a WiFi connection
quecpi_config wifi delete <connection uuid>
