Introduction to EG91X Evaluation Board
Supported Module List
Feature List
Basic Overview
The QuecPython_EG91X series C1-P02 evaluation board is a compact and portable "pocket-sized" board designed specifically for QuecPython.
The main equipped modules are the EG915U series LTE Cat 1 wireless communication modules, which are also compatible with Quectel's EG91 series, EG95 series, BG95 series, and BG96 modules in terms of packaging. This allows for seamless switching between 2G and 4G networks to meet the application requirements of different industries.
The evaluation board has a built-in Type-C interface, making it convenient for development. Developers only need a USB Type-C cable to easily use the evaluation board.
Additionally, the evaluation board is compatible with the expansion board of Raspberry Pi Zero, which can be directly used on the evaluation board.
Evaluation Board Resources
Function Description
The main component and interface placement of the evaluation board is shown in the following figure:
Evaluation board dimensions:
The main pin placement of the evaluation board is shown in the following figure:
Note
For more information about the evaluation board, please visit https://developer.quectel.com/en/resource-download?cid=252.
Evaluation Board Configuration
The detailed assignment of the peripheral interfaces on the evaluation board is as follows:
No. Name Model Silkscreen Comment
1 USB Type-C Interface - - -
2 SIM Card Slot 1 SMN-315-ARP7 SIM1 Nano-SIM
3 SIM Card Slot 2 MUP-C7809-1 SIM2 E-SIM
4 SD Card Slot TF-101A-P3 SD 2.0 Before using the SD card, enable SD to provide power to the SD card in the 10-Pin Header.
5 USB Power Supply Switch - USB_ON/OFF When the switch is normally closed, Type-C supplies power to the module and evaluation board, and USB can be connected normally. When the USB switch is normally open, Type-C supplies power only to the evaluation board. In this case, the module is not powered.
6 MIPI Interface - MIPI_DSI When the main module is EG91X series, it supports MIPI LCD and is fully compatible with Raspberry Pi peripherals.
7 Camera Interface - - The evaluation board supports customized SPI cameras with a maximum of 300,000 pixels.
8 MIC&SPK Interface AW8733A- +MIC-/-SPK+ -
9 40-Pin Header - - Onboard 40-Pin header; For details, see the above figure and table.
10 10-Pin Header - - Onboard 10-Pin header; For details, see the above figure and table.
11 ADC Interface - ADC1_IN ADC testing interface
12 PWK Botton - PWK Turn-on button
13 RST Button - RST Reset button
14 BOOT Button - BOOT Firmware burning button
15 Antenna Interfaces - LTE
DIV/WIFI/BT
GNSS
LTE antenna connector
DIV/Wi-Fi/Bluetooth antenna connector
GNSS antenna connector
The evaluation board has 5 functional indication LEDs, as follows:
  • P21: Power indication LED.
  • PSM: Module Pin 1, PSM indication LED.
  • SCK1: SIM1 detection indication LED, lights up when SIM1 is inserted.
  • SCK2: SIM2 detection indication LED, lights up when SIM2 is inserted.
  • PWR: Power indication LED.
The positions of the above indication LEDs refer to the silkscreen on the top of the evaluation board mentioned in the previous text (the side where the module is located is the top).
Evaluation Board Interfaces
Pin Assignment of 10-Pin Header
Header No. Silkscreen Function
10-Pin 1 PWK_AUTO POWERKEY
10-Pin 2 PWK_AUTO GND
10-Pin 3 VDD_EXT 1.8 V
10-Pin 4 VDD_EXT VDD_EXT
10-Pin 5 MODULE_EN 3.8 V
10-Pin 6 MODULE_EN 3.8 V
10-Pin 7 SD_EN SD_EN
10-Pin 8 SD_EN 3.3 V
10-Pin 9 GNSS_EN 3.3 V
10-Pin 10 GNSS_EN GNSS_EN
  • 1 & 2: Auto turn on
  • 3 & 4: Provide power externally when connected and test power consumption when disconnected
  • 5 & 6: Connect DCDC to power the module
  • 7 & 8: Enable SD power supply
  • 9 & 10: Enable GNSS active power supply
When testing power consumption, make sure to switch off the USB power supply switch (USB_ON/OFF) on the back of the evaluation board.
Singular-pin Assignment of 40-Pin Header
No Name Function Multiplexing Function NO Name Function Multiplexing Function
1 3V3 - 3.3 V Output 2 5V - 5 V Output
3 SDA I2C1_SDA
GPIO14
I2C1 Data
General Purpose Input/Output
4 5V - 5 V Output
5 SCL I2C1_SCL
GPIO13
I2C1 Clock
6 GND - Ground
7 P92 GPIO30 General Purpose Input/Output 8 TXD UART1_TXD UART1 Send
9 GND - Ground 10 RXD UART1_RXD UART1 Recv
11 P116 GPIO41 General Purpose Input/Output 12 P05 GPIO2
SPI1_CS
SPI1 Chip Select
13 P16 GPIO24 General Purpose Input/Output 14 GND - Ground
15 P42 GPIO26 General Purpose Input/Output 16 P21 GPIO17 General Purpose Input/Output
17 3V3 - 3.3 V Output 18 P111 GPIO38 General Purpose Input/Output
19 MO0 SPI0_MOSI
GPIO15
SPI0 Master Output Slave Input
20 GND - Ground
21 MI0 SPI0_MISO
GPIO21
SPI0 Master Input Slave Output
22 P37 GPIO23 General Purpose Input/Output
23 CLK0 SPI0_CLK
GPIO10
SPI0 Clock
24 CS0 SPI0_CS
GPIO9
SPI0 Chip Select
25 GND - Ground 26 P83 GPIO28 General Purpose Input/Output
27 P85 GPIO18 General Purpose Input/Output 28 P86 GPIO19 General Purpose Input/Output
29 P84 GPIO29 General Purpose Input/Output 30 GND - Ground
31 P104 GPIO34 General Purpose Input/Output 32 P20 GPIO16
PWM0
PWM0 Output
33 P105 GPIO35 General Purpose Input/Output 34 GND - Ground
35 P07 GPIO04
SPI1_MISO
SPI1 Master Input Slave Output
36 P106 GPIO36 General Purpose Input/Output
37 P108 GPIO37 General Purpose Input/Output 38 P06 GPIO3
SPI1_MOSI
SPI1 Master Output Slave Input
39 GND - Ground 40 P04 GPIO1
SPI1_CLK
SPI1 Clock
Quick Start Guide
Hardware Preparation
  • Step 1: Required Items
    • Development board
    • USB-C cable (A-to-C)
    • Windows 10 PC
    • Nano-SIM card
    • 4G antenna
  • Step 3: Connect the Board
    • Power the board via USB-C.
  • Step 4: Power On
    • Press and hold PWK until the power indicator light on the mainboard (labeled as POW) lights up.
    • If you short-circuited PWK_ON, there's no need to press PWK; the board will power on automatically.
Driver Installation
Tool Installation
Firmware Burning
  1. Firmware Download: Get the latest QuecPython firmware from QuecPython Firmware Page.
  2. Burning Steps:
    • Choose the .bin firmware file
download_firmware1
download_firmware2
download_firmware3
REPL Debugging
hello
First Script Development
Writing a Script
Create helloworld.py:
File Transfer
download_script1
download_script1
Running Scripts
Execute via REPL:
Stopping Program Execution
✓ ✓ ✗ (1) Press Ctrl + C to interrupt the program execution
✓ ✗ ✓ (1) Press Ctrl + A to enter RAW mode
✓ ✗ ✗ (1) Press Ctrl + C to interrupt the program execution
✗ ✓ ✓ (1) Press Ctrl + D to restart the QuePython virtual machine
✗ ✓ ✗ (1) Press Ctrl + D to restart the QuePython virtual machine
✗ ✗ ✓ (1) Press Ctrl + C to interrupt the program execution
✗ ✗ ✗ (1) Press Ctrl + C to interrupt the program execution
Low Power Consumption Testing Guide
The EG915U module supports multiple operating modes, each with distinct power consumption characteristics. The common operating modes are as follows:
ACTIVE: The module is engaged in LTE data transmission, GSM calls, or executing RTOS logic. Power consumption varies significantly depending on specific tasks and network communication standards, as both CPU power usage and RF power levels differ across scenarios.
IDLE: The module is in an idle state with hardware fully powered and RTOS running, but no active threads. It resumes operation immediately upon task initiation or incoming network activity. ECX00U series modules reduce clock frequency in IDLE mode, entering a light sleep state (disabling high-speed clocks while keeping the CPU active).
Sleep: Sleep mode requires the module to be idle with autosleep enabled. In this mode, RTOS pauses, clock frequency slows, and peripheral controllers (UART, SPI, etc.) are powered down, retaining only essential interrupt controllers to minimize power consumption.
PSM: PSM (Power Saving Mode) is a 3GPP-defined low-power mode where the module periodically wakes to perform tasks and remains in PSM sleep otherwise. During PSM sleep, behavior and power consumption resemble a powered-off state.
Power Off: The module is fully powered down, with baseband chips and peripheral controllers disabled (PMIC remains active). It can be awakened via Powerkey or RTC alarm.
Module Model EG915U
IDLE (LTE FDD@64ms) 13.0 mA
SLEEP (LTE FDD@64ms) 1.8 mA
SLEEP (CFUN0) 1.0 mA
Power Off 32 μA
Test Preparation
  • Step 1: Hardware Setup
    Prepare the following components before starting:
    1. Development Board
    2. USB Cable (USB-A to USB-TypeC)
    3. PC (Windows 10)
    4. SIM Card
    5. 4G Antenna
    6. Power Monitor Mini
  • Step 2: Antenna & SIM Card Installation
    Install the provided antenna into the MAIN antenna socket and insert the SIM card into the development board's SIM slot.
  • Step 3: Board Connection
    Connect the development board's Type-C port to the PC using a USB Type-C cable. Attach the power monitor's positive lead to MODULE_EN's Vbat (refer to BG95 User Guide) and the negative lead to the module's GND. Connection diagram:
    Important!
    Remove all jumper caps during measurements to avoid external interference.
Power Consumption Measurement
Power-Off Current
With the board connected via USB Type-C, power off the module by disabling USB_VBus (set USB switch to "off" on the board's rear). Measure the current while the module is inactive (output pins pulled low/floating). Average current remains stable at microampere levels.
Power-off current measurement
Idle Current
After power-off measurement, press and hold Powerkey to boot the module (default: IDLE mode). The module remains idle with RTOS running but no active threads, ready to resume instantly for tasks or calls.
Idle current measurement
Sleep Current
With autosleep enabled during idle, the module enters sleep mode by deactivating non-essential IP cores (peripherals/interrupts) and reducing clock frequency.
  1. Re-enable USB_VBus.
  2. Open QPYcom Tool and execute:
    import pm
    pm.autosleep(1)  # Enable autosleep
    Sleep current waveform
  3. Disable USB_VBus again (switch to "off").
    API Reference | Details
  4. Sleep current shows periodic spikes:
PSM Current
To enable PSM:
  1. Request PSM from the base station (via ATTACH/TA_UPDATER with timer parameters).
    • Note: Base station determines final timer values.
  2. Once ACT timer expires in IDLE, the module shuts down CPU/RF (partial power-off), retaining wake-up sources (ACT/TAU timers, PSM_INT).
Steps:
  1. Enable USB_VBus.
  2. In QPYcom:
    pm.set_psm_time(tau_uint,tau_time,act_uint,act_time)   # Configure PSM
    PSM current measurement
  3. Disable USB_VBus.
    PSM Guide | API
PSM baseline current (µA-level, similar to power-off):
Notes:
  • Confirm carrier support for PSM and configure compatible network standards (this test uses catM).
  • Additional guidance.
