QuecPython BG&EG Core EVB Introduction
Quick Start
Supported Module List
Feature List
The QuecPython BG&EG series core board (PH-7 (C4-P02)) is a core development board specifically designed for QuecPython with minimal functionality. The core board is designed with a 2.54mm pin arrangement, providing 38 PIN pins, including functional pins and enable control pins. Mainly providing support and convenience for customer development, debugging, and mass production equipment. The core board of the series is applicable to the entire BG95 series, EG915UEUAB, EG915ULAAB, EG912UGLAA and other EG series, including but not limited to the above module models.
Core EVB View
The main components and interface layout of the development board are shown in the following figure.
  • Charging and USB: When inserting the Type-C interface to connect to USB, the charging function is enabled by default and cannot be turned off. If the charging function is not used, there is no need to pay attention.
  • GNSS: The GNSS function depends on the module model. Taking BG95 as an example, the core board defaults to using active antennas and has already enabled power supply to the active antennas by default.
  • SD & SIM Card Slot.
  • 38 Pin.
  • Antenna Interface。
Documents Download
EVB Resources
The main pin layout of the development board is shown in the following figure.
Quick Start Guide
Hardware Preparation
  • Step 1: Required Items
    • Development board
    • USB-C cable (A-to-C)
    • Windows 10 PC
    • Nano-SIM card
    • 4G antenna
  • Step 3: Connect the Board
    • Power the board via USB-C.
  • Step 4: Power On
    • Press and hold PWK until the power indicator light on the mainboard (labeled as POW) lights up.
    • If you short-circuited PWK_ON, there's no need to press PWK; the board will power on automatically.
Driver Installation
Tool Installation
Firmware Burning
  1. Firmware Download: Get the latest QuecPython firmware from QuecPython Firmware Page.
  2. Burning Steps:
    • Choose the .bin firmware file
download_firmware1
download_firmware2
download_firmware3
REPL Debugging
hello
First Script Development
Writing a Script
Create helloworld.py:
File Transfer
download_script1
download_script1
Running Scripts
Execute via REPL:
Stopping Program Execution
✓ ✓ ✗ (1) Press Ctrl + C to interrupt the program execution
✓ ✗ ✓ (1) Press Ctrl + A to enter RAW mode
✓ ✗ ✗ (1) Press Ctrl + C to interrupt the program execution
✗ ✓ ✓ (1) Press Ctrl + D to restart the QuePython virtual machine
✗ ✓ ✗ (1) Press Ctrl + D to restart the QuePython virtual machine
✗ ✗ ✓ (1) Press Ctrl + C to interrupt the program execution
✗ ✗ ✗ (1) Press Ctrl + C to interrupt the program execution
