EC800X QuecDuino EVB Introduction
Supported Modules
Supported module models
Feature List
Basic Overview
The EC800X QuecDuino EVB is equipped with Quectel EC800 series modules. It supports the following module series:
EC800M series, EC800K series, EG800K series, EC800E series, etc.
Rendering
The main components and interface layout of the development board are shown in the figure below.
Document download
EC800X-QuecDuino-EVB
EVB Resources
EVB Interface
Interface Definition / Pinout
Pin Header Pin No. Comment Feature
BOOT - Module USB_BOOT Pin Pull high or low (depending on the specific module model) to enter force download mode
NC - floating -
RST - Module RESET Pin Pull low to reset
3.3V - Power Output 3.3V/200mA
5V - Power Input/Output 5V/2A(Leave floating/unconnected for V1.1 version)
GND - Ground -
GND - Ground -
A0 - Module ADC0 Input Pin 0-1.2V
A1 - Module ADC1 Input Pin 0-1.2V
D0 19 I/O 3.3V
D1 20 I/O 3.3V
D2 21 I/O 3.3V
D3 25 I/O 3.3V
0 - Main UART Receive 3.3V
1 - Main UART Transmit 3.3V
2 - Auxiliary UART Receive 3.3V
3 - Auxiliary UART Receive 3.3V
4 23 I/O 3.3V
5 22 I/O 3.3V
6 28 I/O 3.3V
7 29 I/O 3.3V
8 58 I/O 3.3V
9 80 I/O 3.3V
10 31 I/O 3.3V
11 32 I/O 3.3V
12 33 I/O 3.3V
13 30 I/O 3.3V
14 - Ground -
15 - NC Leave floating
16 66 I/O 3.3V
17 67 I/O 3.3V
The main pin layout of the development board is shown in the figure below.
Tips
For more information about the EVB, please visit https://developer.quectel.com/en/resource-download
EVB Configuration
The EVB is equipped with various sensors and other peripherals. The pins of peripherals are shown in the table below.
No. Name Model Supports Interface Type Pin No.
1 USB Interface - yes Type-C -
2 LED Indicator - yes GPIO -
3 Microphone B4013AM423-092 yes SPK -
  • Quick Start Guide
    Hardware Preparation
    • Step 1: Required Items
      • Development board
      • USB-C cable (A-to-C)
      • Windows 10 PC
      • Nano-SIM card
      • 4G antenna
    • Step 3: Connect the Board
      • Connect the development board's Type-C port to a computer USB port using a USB Type-C cable to supply power. Before powering on, ensure to short the VUBS EN, VDD_EXT EN, and VBAT EN jumper pins.
    • Step 4: Power On
      • Press and hold S1 until the power indicator light (labeled D1 on the board) on the main board illuminates. If PWK_ON has been shorted in the previous step, there is no need to press and hold the power key, as the system will boot automatically.
      For detailed information regarding the development board's indicator lights and power settings, please refer to the specifications document.
    Driver Installation
    Tool Installation
    Firmware Burning
    1. Firmware Download: Get the latest QuecPython firmware from QuecPython Firmware Page.
    2. Burning Steps:
      • Choose the .bin firmware file
      • For BG95, enable DM serial port before burning.
    download_firmware1
    download_firmware2
    download_firmware3
    REPL Debugging
    hello
    First Script Development
    Writing a Script
    Create helloworld.py:
    File Transfer
    download_script1
    download_script1
    Running Scripts
    Execute via REPL:
    Stopping Program Execution
    ✗ (1) Press Ctrl + C to interrupt the program execution
    ✗ ✓ (1) Press Ctrl + A to enter RAW mode
    ✗ ✓ ✓ (1) Press Ctrl + D to restart the QuePython virtual machine
    ✗ (1) Press Ctrl + D to restart the QuePython virtual machine
    ✗ ✓ (1) Press Ctrl + C to interrupt the program execution
