QuecPython Yttrium Evaluation Board Introduction
Supported Modules
Features
The QuecPython Yttrium evaluation board is a Python-ecosystem development board designed specifically for development, debugging, and solution demonstration scenarios. The main module is equipped with the EG800Z LTE wireless communication module.
The board features dual USB Type-C interfaces for convenient power supply and serial debugging. It also supports an external power terminal supply solution, allowing flexible adaptation to different development scenarios.
It integrates a rich set of interfaces including LCD display, camera capture, audio input/output, cellular network, 100 Mbps Ethernet, industrial-grade CAN/RS485 buses, and more. This makes it well-suited for IoT development, industrial communication, multimedia interaction, and various other application scenarios.
Hardware Description
The main components and interface layout of the evaluation board are shown below:
Evaluation board dimensions (top view):
Top view and bottom view of the evaluation board:
img img
Downloads
Board Resources
Basic Specifications
Item Specification
Package PCBA
Dimensions (mm) (122.0 ± 0.2) × (68.9 ± 0.2) × (1.6 ± 0.1)
Weight (g) 49.2 ± 0.2
Operating Temp. -10 ~ +50 °C
Storage Temp. -20 ~ +60 °C
Power Supply USB Type-C 5V ± 5% / 3.81mm terminal block 5V ± 5%
Firmware Upgrade USB / OTA
Board Interfaces
The detailed assignment of the board interfaces is as follows:
No. Interface Description
Reserved Ports
6 (J0702) 1 × 8-Pin Header MAIN_TXD, MAIN_RXD, LCD, CTP_INT, GND, ADC signals
6 (J0703) 1 × 8-Pin Header QSPI_D3, QSPI_D2, LCD signals
Buttons & Switches
2 S0301 Determines the board power source: toggle up for external DC 5V; toggle down for USB Type-C 5V
5 S0705 DIP switch for LED_PWM4 / GPIO2 multiplexing. S0705 pins 2-4 ON + S0502 pins 1-3 OFF: LED_PWM4 controls IND_LED. S0705 pins 2-4 OFF + S0502 pins 1-3 ON: LED_PWM4 provides PWM4 audio output. S0705 pins 1-3 ON: GPIO2 controls buzzer BEEP
11 S0401 Determines main UART routing: toggle left for USB Type-C UART; toggle right for RS485
15 S0601 DIP switch for SPI0 routing to NET or FLASH
17 S0501 / S0502 S0501 ON + S0502 OFF: module PCM pins route through Codec to amplifier and speaker. S0501 OFF + S0502 ON: module PWM4 pin routes through filter circuit to amplifier and speaker
19 WAKEUP Press to wake up the module
20 USB_BOOT Press before power-on to enter forced download mode
21 RESET Press to restart the module
22 PWRKEY Press to power on the module
Communication
12 RS485 RS485 connector: RS485_A, RS485_B, GND; half-duplex
13 CAN CAN connector: CAN_H, CAN_L, GND; 1 Mbps data rate
14 Ethernet 1 × RJ45 connector, supports 10/100 Mbps Ethernet; Link LED and Activity LED indicators
Camera
8 (J0501) 1 × 18-Pin FPC Camera signal connector, supports 0.3 MP, SPI interface
Buzzer
4 BEEP Buzzer; S0705 pins 1-3 ON: GPIO2 controls buzzer BEEP
LCD Display
3 1 × 14-Pin Header LCD resolution 320×480; 4.0-inch screen; capacitive touch panel; display interface: 4-Line SPI, driver ICST7796S; touch interface: I2C, driver FT6336U
Audio
16 SPEAK Audio output, external speaker support
25 MIC Onboard microphone SOM4013SL-G423L
USB Ports
9 USB Type-C 1 × USB 2.0 Type-C, up to 480 Mbps data rate; can serve as power input
10 USB Type-C to UART 1 × USB 2.0 Type-C, up to 12 Mbps data rate; converted to TTL via XR21B1411IL16 chip, connected to module main UART
LTE Module
7 SIM Card Slot MUP-C7081-2, Nano SIM, 1.8V / 3.0V
18 Antenna Connector Supports external LTE antenna
Power & Startup
1 External DC Input 3.81mm terminal block, 5V ± 5%
23 (J0203) VBAT & VBAT12 Test Point Remove resistor R0204 above this test point; connect an ammeter in series to measure module current
24 PWRKEY & GND Test Point Short before power-on for auto-startup
Reserved Port Pin Assignments
J0702 8-Pin Header Pin Assignments
Header Pin Signal Function
J0702 8-Pin 1 MAIN_TXD Main UART transmit
J0702 8-Pin 2 MAIN_RXD Main UART receive
J0702 8-Pin 3 LCD_SIG LCD related signal
J0702 8-Pin 4 CTP_INT Capacitive touch interrupt
J0702 8-Pin 5 GND Ground
J0702 8-Pin 6 ADC0 ADC input signal
J0702 8-Pin 7 ADC1 ADC input signal
J0702 8-Pin 8 GND Ground
J0703 8-Pin Header Pin Assignments
J0703 8-Pin 1 CS SPI chip select
J0703 8-Pin 2 RST SPI reset
J0703 8-Pin 3 QSPI_D1 QSPI bus data 1
J0703 8-Pin 4 QSPI_D0 QSPI bus data 0
J0703 8-Pin 5 CLK LCD clock signal
J0703 8-Pin 6 READ Ground
J0703 8-Pin 7 QSPI_D3 QSPI bus data 3
J0703 8-Pin 8 QSPI_D2 QSPI bus data 2
Key Features
Category Description
USB Interface 1 × USB 2.0 interface, up to 480 Mbps; 1 × USB Type-C connector, can serve as power input
UART 1 × USB 2.0 interface, up to 12 Mbps; 1 × USB Type-C connector, can serve as power input; converted to UART via XR21B1411 chip, connected to module main UART
RS485 Main UART converted to RS485 via a DPDT switch and RS485 transceiver (SIT3088E)
LCD Interface LCD resolution 320×480; 4.0-inch screen; capacitive touch panel; display interface: 4-Line SPI, driver ICST7796S; touch interface: I2C, driver FT6336U
Audio — Speaker 1 × CS8126, 2W Class-D audio amplifier, supports audio output
Audio — MIC 1 × SOM4013SL-G423L onboard microphone, supports audio input
Audio — Codec 1 × ES8311 Codec chip, connected to module via PCM and I2C for audio functionality
Compatible Audio Output 1 × PWM signal and filter circuit designed for validating PWM audio output
Camera 1 × 16-pin FPC connector; camera interface: SPI, driver GC032A; resolution: 0.3 MP
CAN Integrated CAN controller via CAN transceiver SIT65HVD230, compliant with ISO 11898; supports up to 120 nodes on a single bus; max data rate 1 Mbps
SIM Card 1 × MUP-C7081-2 slot, supports Nano SIM; 1.8V and 3V dual voltage
Reserved Headers 2 × 8-Pin headers; ADC, main UART, QSPI signals brought out
Buttons 1 × PWRKEY power-on button; 1 × RESET reset button; 1 × BOOT forced download button; 1 × WAKEUP wake-up button
LED Indicators PWRLED (red): module power indicator; INDLED (green): module operation indicator, user-programmable
Buzzer 1 × Beep buzzer
Onboard Buttons and Indicators
The board features 4 functional buttons and 2 status LEDs:
  • PWRKEY: Power-on button. Long press to power on the module.
  • RESET: Reset button. Press to trigger a module restart.
  • BOOT: Forced download button. Press and hold before power-on to enter forced firmware download mode.
  • WAKEUP: Wake-up button. Press to wake the module from sleep.
  • PWRLED: Red power indicator. Stays lit when the module is properly powered.
  • INDLED: Green operation indicator. Supports user-defined functionality for operation status indication.
Quick Start Guide
Hardware Preparation
  • Step 1: Required Items
    Items required before getting started:
    1. Evaluation Board
    2. USB Cable (USB-A to USB Type-C)
    3. PC (Windows 10)
    4. SIM Card
    5. 4G Antenna
    Attach the provided antenna to the MAIN antenna port and insert the SIM card into the SIM card slot.
  • Step 3: Connect the Board
    Connect the board to your PC using a USB Type-C cable via the Type-C/Micro USB port for power supply.
    When the PWR LED is constantly lit, the board is properly powered.
  • Step 4: Power On
    Long-press PWRKEY to power on. Before pressing PWRKEY, ensure the supply voltage is stable. It is recommended to wait at least 30 ms between power-on and pressing PWRKEY.
    If auto power-on is required and the shutdown function is not needed, short the two pins labeled PWK_AUTO on the 10-Pin header.
    If PWK_ON is shorted in the previous step, the board will power on automatically without long-pressing PWRKEY. After startup, the NET LED will blink, indicating the board has powered on normally.
Driver Installation
  3. Verify installation in Device Manager (look for ports starting with "Quectel USB"). Ignore unrelated devices such as "Mobile ECM Network Adapter" or "CDC Ethernet Control Model (ECM)".
Tool Installation
  • QPYcom: The dedicated QuecPython development and debugging tool for code debugging, log analysis, file transfer, firmware burning, and firmware merging. Download from QuecPython Tools. No installation required — extract and use directly.
  • VSCode Plugin: Search for "QuecPython" in the Visual Studio Code extensions marketplace to install the plugin, which provides code hints, code completion, and serial debugging features.
Firmware Burning
  1. Firmware Download: Get the latest QuecPython firmware from the QuecPython Firmware page.
    Select the firmware that matches your module model. The firmware file name follows the pattern QPY_OCPU_<version>_<module_model>_FW. Download the latest version unless you have specific requirements.
    The downloaded package is a ZIP file. Extract it (avoid paths containing Chinese characters, spaces, or special characters) to obtain the .bin firmware file and a .md changelog.
download_firmware1
download_firmware2
download_firmware3
  1. Burning Steps:
    • Open QPYcom, go to the download page, and click Create to set up a new firmware project.
    • Select the .bin firmware file for your module model.
    • Set the download mode to "Download FW".
    • Click Download FW to start burning. A progress bar will show the status, and a dialog will confirm completion.
REPL Debugging
  1. Connect via QPYcom — select the Quectel USB REPL Port and open the "Interactive" tab.
  2. Click "Open Serial Port" and test with print('hello world').
hello world
hello
Note: When using the interactive interface, ensure you type in English characters — Chinese characters will be filtered.
First Script Development
Writing a Script
Create helloworld.py:
print("hello world")
Download the file to the module using QPYcom and run it.
File Transfer
Method 1 — Drag and Drop:
download_script1
  • Open the serial port and use the +/ buttons on the file page to upload and delete files,
  • or drag and drop files/folders from the left (local) pane to the right (module) pane.
Method 2 — Download Script:
download_script1
  • Create a user project and add your script files in the "User Script" area.
  • Set the download mode to "Download Script" and click to start. A progress bar will show the download status.
Running Scripts
Execute via REPL:
Or use QPYcom's file page: select the script file and click the button to execute.
Stopping Program Execution
(1) Press Ctrl + A to enter RAW mode
(2) Press Ctrl + D to restart the QuecPython VM
(3) Press Ctrl + B to return to normal interactive mode
(4) If the above fails, re-burn the firmware
(1) Press Ctrl + C to interrupt execution
(2) If the above fails, re-burn the firmware
(4) If the above fails, wait for the program to finish
(1) Press Ctrl + D to restart the QuecPython VM
(2) If the above fails, directly restart the module
(2) If the above fails, re-burn the firmware or directly restart the module
